Maintenance
starcheckdriver
Does anyone know if FAR 135 operators can allow pilots to perform any maintenance functions such as adding oil, draining pitot-static systems, etc.?
No reference for you but adding oil and fuel are considered "servicing" the aircraft and is not considered maint.
?!..Absolutely NOT!!...135 Pilots are NOT to touch anything beyound arm's reach of the Captain's Chair.
~Greasel
~Greasel
Right...ya gotta get a $5/hour line guy to add oil...just make sure you check the cap when he's done.
Fly safe!
David
Under normal circumstances nosehair is correct. HOWEVER, it can and has been done. You can have this approved in your op spec. There are a number of 135 helo operators that have approvals for pilots to perform varying levels of maintenance that would otherwise not be permitted.
I have heard both sides of the argument and understand that FAR 43.3 (I think) states that 135 operators cannot allow pilots to do maintenance. However, where is it stated that things like adding oil are not considered maintenance?
14CFR43, appendix D spells out what may be performed as preventive maintenance, but that excludes aircraft that are used in part 121 or 135 certificates. As mentioned earlier, this may be changed depending on the operators ops specs. But if a discrepancy is found by the crew, it must still be rectified by a maintenance action.
Adding oil is considered servicing, so thats excluded. Draining water from a static line depends. Is there a quick drain valve that can be opened to allow the moisture to be drained? If you have to open a line, as in removing a fitting, then no. If the static system is opened, then a static system test must be performed.
Hey!! Don't get me in this...I was only being facet...fasis..fashis.., uhh, just kiddin'.
Of course you can service the airplane....(rolleyes)
Hmmm, lots of opinions here. To properly answer the original question, the answer is no, unless you get it approved in your ops specs, or it is in the POH/AFM of your aircraft, and their are numerous examples where approval was given in ops specs for pilots to conduct maintenance. As I mentioned, it is not uncommon with 135 helo operators. As for part 121, numerous operators use PFE's who are expected to resolve maintenance discrepancies, and do.
The Director of Maintenance can authorize a pilot to perform a function as a delegated act under the authority of the maintenance department for the company. However, in order to do so, you must be knowledgeable in the techniques and practices necessary to accomplish the task, must have access to the current maintenance publications for the appliance, aircraft, powerplant, or accessory, you must have had training on that function, must have the calibrated tools called out for in the manufacturers publication, must be under a drug program (a given, if you're flying the airplane), and the work must be done to industry standard and to any specific standards spelled out in the manufacturers current maintenance pubs. You must also have undergone any company mandated training (eg, if the company GOM calls out flight safety as the maintenance training vendor, then you need to have attended the requisite FSI maintenance courses...not pilot courses...for that type). You'll also need specific training done and signed off in your employee records regarding Section D of your OpSpecs.
That all applies weather you're checking oil or performing a maintenance act.
If you're servicing the oil in a turbine engine, it needs a writeup. It may not necessarily be included in the permenant logs (seldom if ever is), but needs to be retained until oil is either added again or the oil is changed. This is generally kept in the flight logs, and is just as official a maintenance entry as any.
Same goes for a simple FMS database update.
You can do the work, if authoirzed, but still need to meet all the requirements that any maintenance personnel must meet. Additionally, there are a lot of functions you just can't perform if you're non-certificated, and a lot of things you can't sign off unless you're certificated. Any configurational changes require a signature, endorsement, and a rework of the weight and balance...which also requires a mechanic certificate and associated log entry.
Don't forget that any maintenance act you do will require a signature somewhere. Without the appropriate log entries, line 6 of your airworthiness certicate will tell you the aircraft is no longer airworthy, and that opens you up to more violation potential.
When serving as DOM in the past, I've caught pilots doing things on their own, and I subsequently grounded the airplane and required an inspection. Such acts, and the authorization to delegate or permit acts beneath the DOM, are at the purview of the DOM. It's his butt, his liability, and his responsibility.
