stupidpilot
Registered Moron
- Sep 6, 2005
Oops! The aircraft fueler gets smoked again! Thanks for playing!http://www.faa.gov/library/manuals/aviation/instrument_procedures_handbook/media/CH-03.pdf
ATC issues speed adjustments if you are being radar controlled to achieve or maintain required or desired spacing. They express speed adjustments in terms of except that at or above FL 240 speeds may be expressed in terms of Mach numbers in 0.01 increments. The use of Mach numbers by ATC is restricted to turbojets. If complying with speed adjustments, pilots are expected to maintain that speed within plus or minus 10 knots or 0.02 Mach.
