Hi,
I am having a little bit a of problem that I am helping someone with. The engine is a lycoming IO-360. The fuel spider and fuel control unit were removed and rebuilt by Avstar when the oil pump AD was done recently. Increasingly the aircraft has been hard to start when cold and impossible to start when hot. At one point it was impossible to start when cold also but the problem was narrowed down to a broken wire with the bendix shower of sparks. That has since been fixed and the gap adjusted on the shower of sparks to .018. The mags are slicks, and did have some corroded contacts on the distrubutor and were cleaned up. We are sort of at a loss for what is going on. The engine will normally fire once or twice and backfire when you try to start hot. When could it will do the same but normally catch enough to start, run it for a 15 or so minutes and it can't be restarted. Fuel system? Mags? Shower of spark? The compressions are fine however the engine maybe be slightly rich when running.
Any ideas?
Any ideas?
