And when it comes to anything related to SIC, EVERYone has a different interpretation!777_Jackpot said:Unless someone else has a different interpretation. Hope that helps
777_Jackpot said:61.51 PILOT LOGBOOKS
(g) Logging instrument flight time. (1) A person may log instrument time only for that flight time when the person operates the aircraft solely by reference to instruments under actual or simulated instrument flight conditions.
No, you can't log instrument time while SIC PNF because "you" are not the person operating the aircraft, that is you are not actually flying. The number of pilots required on the aircrafts type certificate and the operating part would not be a factor. Unless someone else has a different interpretation. Hope that helps
midlifeflyer said:FWIW, cc, I've never seen a list of rules for the "generally accepted right way to log" time apart from the rules for meeting the FAA's requirements certificates, ratings, or currency (with perhaps the odd extra column for insurance or employment needs)
777_Jackpot said:No, you can't log instrument time while SIC PNF because "you" are not the person operating the aircraft, that is you are not actually flying. The number of pilots required on the aircrafts type certificate and the operating part would not be a factor. Unless someone else has a different interpretation. Hope that helps
Just to clarify, a CFI can log PIC in actual when giving instruction in actual whether or not the CFI is acting as PIC. The CFI can be out of every type of currency that exists and without a medical for the past 10 years and can still log it.check6 said:Can't a CFII log PIC IFR if in actual even though they may not be manipulating the controls?? As an authorized instructor, you can log PIC time as long as you are acting just as that.
midlifeflyer said:Just to clarify, a CFI can log PIC in actual when giving instruction in actual whether or not the CFI is acting as PIC. The CFI can be out of every type of currency that exists and without a medical for the past 10 years and can still log it.
