With or without a Hobbs, the "legal" method of calculating time for logging purposes is:If you're flying an airplane without a Hobbs meter, what is the prescribed method on LEGALLY logging that time? Is it legal to note engine start time and shutdown and use that for time logged?
...and then you get into airplanes without Hobbs meters again, and you do the same thing you're doing nowThat is correct. From the time the aircraft's engine(s) are started for the purpose of flight to shutdown is loggable time. As you advance in your career the Hobbs meters in the aircraft you will be flying will only be running when the aircraft is airborne. Therefore taxi time is alloted to your logged time.
