outdoorsguy
Active member
- Mar 22, 2006
Thedude said:Only if you have passed a 135 SIC checkout and the company's Ops Specs allows for and SIC in single pilot aircraft.
Do a search ...this has been covered many times.
A Squared said:Uhhh. no, in order to log SIC, the SIC has to be required. allowed does not equal required.
varicam said:I'd like to differ on this, I believe you have it bass ackwards. FAR 135.101 requires a SIC for Part 135 passenger IFR flight. Naturally, a SIC needs current training and checking and must be assigned as the SIC on a flight in order to act as SIC and log the time. Any reference to "allowed" in this context applies to an autopilot which may be allowed (authorized) in lieu of a SIC if all the hoops are jumped through. But, an operator authorized to use an autopilot may still elect to assign a SIC if the operator so chooses.
varicam said:Therefore, a SIC is never "allowed", but is either required and can log time or is not required and cannot touch the controls nor log time.
varicam said:The FAA Chief Counsel has put this issue to bed a dozen or so times over the years.
If a pilot designated as SIC is not required by either the aircraft type certificate or the regulations under which the operation is being conducted (e.g. 14 CFR part 135.103), as is the case in the scenario above, then the pilot designated as SIC may not log flight time as SIC.
Let me ask you something; Did you think you were going to get away with nobody calling you on your lie?[/quote said:I give up! You quote the very document that belies your interpretation and yet find that it says something it clearly doesn't. Take it to your lawyer and maybe he or she will explain it to you.
midlifeflyer said:I don't understand the argument. The FAA Legal Counsel have it A Squared have it exactly right and the opposing view, especially those citing pretend-SIC programs with imaginary FAA backing are living in a world where they try to bend fairly clear rules to fit what they want to do.
What's so difficult about that? An OpSpec that says you "may" have an SIC an insurance company that insists of an SIC; a pilot who wants an SIC to help out - none of them make an SIC "required" by a regulation.
transpac said:BTW, could you post an excerpt from an Op spec that says you "may" have a SIC? I've never actually seen anything like that.
CloudyIFR said:You won't, because the Regs say an A/P in Lieu of an SIC. So it doesn't need to be in the Ops Specs.
The A/P can work all day long and still use an SIC legally and rightly so, assuming carrying passengers or flying over 8 hours to 10 hours in any operation.
Curtis
varicam said:I give up! You quote the very document that belies your interpretation and yet find that it says something it clearly doesn't. Take it to your lawyer and maybe he or she will explain it to you.
This pilot may be designated as SIC even though the aircraft being flown does not require more than one pilot and the regulations under which the flight is being conducted do not require more than one pilot. Finally, this pilot may log PIC time for those portions of the flight when he or she is the sole manipulator of the controls of an aircraft for which the pilot is rated, but may not log any portion of the flight as SIC time.
dardar said:yeah, if it's in the ops specs. Airnet, for example, has a program where you can fly as an sic on a baron or something until you get your 1200 135mins. It used to address this issue somewhere on their website, but I can't find it now. Pretty much, I believe it used to be under the FAQs, Airnet brought this issue up with the FAA since so many applicants were asking about the legality, and the FAA said it was legit.
So no, you don't have to carry passengers and it doesn't have to be a two pilot airplane. It just depends on the ops specs.
transpac said:Well, as I understand the orginal question, it concerned "required" SICs, as defined in Part 135.101. The poster wanted to know if a SIC could be used in lieu of an autopilot. Since only IFR passenger carrying operations exercise autopilot authorizations, my assumption is that he wasn't referring to a "pretend" setup in a VFR or cargo scenario.
Can you log SIC time flying for a 135 operator if the aircraft is flown single pilot when a SIC is not available? Example of aircraft could be a Caravan, BE99, or Metroliner ect...
transpac said:The Chief Counsel has published an opinion to the effect that the presence of an autopilot authorization does not preclude an operator from assigning a qualified SIC to a flight and does not preclude such a SIC from logging the time.
transpac said:The answers and quotes from A Squared (and apparently you also) concern non-required SICs as defined by 135.101. The result of all this is confusion with each individual modifying the question to fit a pre-conceived answer.
was appropriately general. As far as I can see, you are the only one who has thought the question was specifically about 135 IFR pax operations with an autopilot. To clarify, when I said "allowed" I didn't mean that a specific allowance was made in the ops specs, rather that as long as an SIC is qualified, trained and checked in accordance with part 135, it's perfectly legal for him to be assigned as an SIC, therfore "allowed" in a more general sense, ie: not prohibited.in order to log SIC, the SIC has to be required. allowed does not equal required.
iflyjets4food said:You can log whatever you want. As long as you aren't using the time to apply for a certificate/rating or for currency requirements.
iflyjets4food said:Add a column in your logbook for time sitting in seat 7c on a Boeing 737. Nothing wrong with it.
That doesn't make the SIC required. The SIC must be required in order to log the time.Hypoxik said:1. 135 Checkride, in which you can fail and go against you record
That doesn't make the SIC required. The SIC must be required in order to log the time.Hypoxik said:2. If something goes wrong/break FAR, you can be violated as an SIC
Not if they understand that it is not legal SIC time. The fact that htere may be ionspectors at some FSDOs who don't understand the regulations doesn't make it legitimate.Hypoxik said:3. The FSDO does count this time towards your ATP
Hypoxik said:4. If the OpSpecs allows/calls for an SIC
Hypoxik said:In fact im going to take your DC6 job with all that SIC time!
Sure. Let's see. Two pilots working for a commercial operator pretending to teach each other while on a compensation flight. Yup. Logging phony instruction is always a solid idea.kansas said:(b) An airline transport pilot may instruct—
(1) Other pilots in air transportation service in aircraft of the category, class, and type, as applicable, for which the airline transport pilot is rated and endorse the logbook or other training record of the person to whom training has been given.
This may be an alternative to logging SIC...log dual received instead, provided the other guy is an ATP.
