Flying Illini
Hit me Peter!
- Mar 9, 2003
Lets say for example I (a private single engine land, Inst. rated pilot) goes out flying with a buddy of mine. My buddy is NOT a CFI. He however already has his complex endorsement and we are flying a piper arrow (complex airplane). If he is the "real" PIC and logs this time, I can not log this complex time also since you cant double log the PIC time.If he didnt log this time as PIC could I?
"Acting" as PIC, standing along, is =never= a sufficient condition for =logging= PIC under the FAA rules.
In the CFI situation, you get to log PIC because you are the sole manipulator. The CFI gets to log it because of a separate rule that says that a CFI can log PIC time for all the time she provides instruction. It had nothing to do with who is handing the controls.
"Rated" means the category and class (and type, if a type rating is necessary for the aircraft) that is listed on the back of your pilot certificate. Nothing else matters. Not instrument ratings. Not endorsements for high performance, complex, tailwheel aircraft. Nothing.
This means that even without category and class ratings, you may log PIC time if you are solo. In addition to the obvious (student solo) it also means, for example, that if you are ASEL and solo in an AMEL or ASES, you may log the time as PIC.
Based on a unpublished 1977 Chief Counsel opinion (there is some reasonable disagreement on whether it's still any good), you may log PIC if you are acting as PIC* and you are the only person on board with the necessary aircraft ratings.
This is the answer to the silly question: "Can I log PIC while I let my two year old fly the airplane?" Frankly, I can't imagine that the FAA gives a hoot about this one way or another.
The analysis is very basic. Which private pilot is flying the airplane? The one who is flying the airplane gets to log the PIC time. The one who is not flying is a passenger.Flying Illini said:Two private pilots rent a SEL aircraft for which they are both rated. Who can log PIC? Can both of them log PIC? Why or why not?
