Logging Pic Time In Actual When Training
be76pilot
Hi, just wanted to know what everyone thought about logging PIC time, while in actual instrument conditions, during your instrument training (instrument instructor on the right of course). I was told that you could go either way with this during my instrument training, so I logged it (all 1.7 hrs worth) as PIC. I was rated in the aircraft of course, so the explanation was that you can log any time in that aircraft as PIC if you are rated in the aircraft. Is this area grey enough to fog up a future interview with an airline? :confused:
Legally, yes you can log it PIC if you are rated and the sole manipulator - however - I hear some airlines don't like to see "PIC and "Dual Received" in the same entry. If you're looking at flying for the airlines, only log PIC time that you are actually ACTING as PIC. 1.7 hours may seem like a lot now, but when you are close to that airline job, it's nothing...
My 2c.
Thanks for the help with my question. I've heard quite a bit on this topic, so if anyone else would like to put a couple cents in, I'd appreciate the info.:)
Log it all as PIC, then if the airlines have a beef with it later, adjust it.
My instructor logged all his dual recieved time as PIC after he got his private. He had his final interview with Expressjet on monday and starts training with them next monday, so that's at least one airline that thinks that logging method is fine.
Go to DOC's FAR forums
If you are up with an instructor, you can log PIC as long as you're rated in the aircraft and are the one flying. If the instructor takes the controls and demonstrates a maneuver, you cannot log that PIC, only dual given. The instructor can log either as PIC.
Appropriately rated means category and class. It doesnt have anything to do with high-performance, complex or tailwheel. You can log PIC time in the plane before you get your endorsement, as long as you are on the controls.
Working on your multi rating, that is a different class of airplane and you cannot log PIC even when you are flying it. Just dual given.
Hey burritos, are you saying that technically you have to add up all of the flight time that your instructor spends demonstrating a maneuver (i.e. a hold or approach) during instrument training, in a plane that you are rated in? Then you have to subtract that time from what you log as PIC. You might have to start bring ing a calculator on your training flights, huh. I have never heard that view before, but it is very interesting.
Question for you guys:
A non-instrument rated private pilot is flying alone, VFR in VMC. Without violating any FAR's, can he log actual instrument time?
be76: yeah, that's what he's saying, although estimating it is adequate for most purposes. "Seems like he was flying demo for about 10 minutes, so call it .2 that wasn't PIC."
Thanks for clearing that up for me snoopy. If anyone asks, I was flying PIC the whole time, while my instructor cought up on some sleep. Ha,Ha. :cool:
This sounds like a trick question to me, so I will bite :)
How about at night inbetween two layers? Or over the ocean at night under an overcast? As long as you are flying "solely to the reference of the instruments" right?
Without question, yes. M. Burritos cited a few examples of situations requiring flight by reference to instruments. A pilot who is not instrument rated, who logs instrument time under such circumstances,should note the circumstances and the reason for logging the time as such, in the remarks section of that particular logbook entry.
Before the airline interview crowd gets to whooping and hollering, can it. ;) There is no issue here. Further, the FAA has released a legal interpretation specifically addressing the matter. Yes, it's perfectly legal, and acceptable, and no interviewer worth his salt is going to bat an eyelid.
The following excerpt from a legal interpetation by the FAA Chief Legal Counsel addresses the issue:
November 7, 1984
Mr. Joseph P. Carr
Dear Mr. Carr:
This is in response to your letter asking questions about instrument flight time.
First, you ask for an interpretation of Section 61.51(c)(4) of the Federal Aviation Regulations (FAR) regarding the logging of instrument flight time. You ask whether, for instance, a flight over the ocean on a moonless night without a discernible horizon could be logged as actual instrument flight time.
As you know, Section 61.51(c)(4) provides rules for the logging of instrument flight time which may be used to meet the requirements of a certificate or rating, or to meet the recent flight experience requirements of Part 61. That section provides in part, that a pilot may log as instrument flight time only that time during which he or she operates the aircraft solely by reference to instruments, under actual (instrument meteorological conditions (imc)) or simulated instrument flight conditions. "Simulated" instrument conditions occur when the pilot's vision outside of the aircraft is intentionally restricted, such as by a hood or goggles. "Actual" instrument flight conditions occur when some outside conditions make it necessary for the pilot to use the aircraft instruments in order to maintain adequate control over the aircraft. Typically, these conditions involve adverse weather conditions.
To answer your first question, actual instrument conditions may occur in the case you described a moonless night over the ocean with no discernible horizon, if use of the instruments is necessary to maintain adequate control over the aircraft. The determination as to whether flight by reference to instruments is necessary is somewhat subjective and based in part on the sound judgment of the pilot. Note that, under Section 61.51(b)(3), the pilot must log the conditions of the flight. The log should include the reasons for determining that the flight was under actual instrument conditions in case the pilot later would be called on to prove that the actual instrument flight time logged was legitimate.
Sincerely,
/s/
John H. Cassady
Assistant Chief counsel
Regulations and Enforcement Division
As for logging instruction received and PIC, there is no issue at all. No airline is going to balk at logging PIC when you're legally justified in doing so...and you're perfectly fine showing that you were receving instruction while acting as PIC. HOWEVER, many airlines and firms will want to see PIC, SIC, and instruction received add up to equal total time. If I am PIC on a flight in which I am receiving instruction, I log both PIC and instruction received on the particular line entry in the logbook. However, the instruction received doesn't show up in the totals at the bottom of the page. In my logbook, only instruction received which cannot be classified as PIC or SIC shows up in the instruction received totals. Therefore, PIC, SIC, and instruction received add up to total time.
Correct. You may only log as PIC that time which meets the requirements of 14 CFR 61.51(e). If your instructor takes the controls to demonstrate something, or flies for a portion of the time you are in the airplane, then you may not log that time, except as instruction received.
Maybe.
--FAA Legal "moonless night" opinion
Ultimately it's the pilot's call whether she needs the instruments in order to keep the shiny side up. But if it were the ocean under the overcast with reported unlimited visibility, it's probably a good idea to write "why" it was logged as instrument time in the comments.
That's right, but I never had a flight instructor demonstrate a hold or approach, and I don't know anyone else who has either. I don't see why it's necessary. Perhaps they are trying to steal stick time from you?
I always demonstrate the first approach in actual IMC. Partly because it usually freaks out the student a bit and it helps if they sit back and watch, partly because I get to log it then :)
