According to one FSDO a few years back, they told me that if the customer requires two pilots for the flight and pays for two pilots then the flight requires two pilots and it can be logged.
Bandit60 said:
And for those who say it is worthless time, they never did that type of flying. In the weather and crap like that. There can be as much to do on a Cessna 402 as there is in a jet. (radios,navigation, etc.)
Good luck and be safe
Timebuilder said:I am certain that you are aware that any interpretation of regs on the FSDO level means nothing. Nada. Zip.............
True. If it is a matter of operational procedure, get it in writing and have the FSDO approve it. Then you are fine. They control the oversight for your certificate.
....If you can show that the SIC was indeed required under the ops specs for the carrier, then you can justify this time from a more firm position.
I just have to jump in here. First the OpSpecs do not really control here. According to FAA Legal, if the company assigns a F/O then the F/O may log the flight time.
there are conditions under 14 CFR 135 operations which do require two pilots regardless of the aircraft type. Examples include takeoffs below 1,800 RVR, carrying passengers in IFR conditions without an autopilot, and whenever the flight crew is being assigned to more than eight hours of flight time.
In most cases, even these requirements do not apply to operations at AirNet, therefore, the SIC logs pilot in command time while being the sole manipulator of the flight controls and logs total time only, when not manipulating the flight controls. (emphasis added)
If the operator assigns a SIC to the flight, they become a required crewmember and therefore may log the flight time as appropriate. And this is according to FAA Legal. There have been several legal interpretations issued by FAA Legal stating that. It has no effect on this why the SIC is assigned.
hi a friend of mine is a first officer on a cessna 402.
The regs allow the operator to conduct IFR operations without a SIC if the aircraft and PIC are single pilot/autopilot authorized. The operative word in the regs and the OpSpec is MAY. It does not require the operator to conduct single pilot operations. If the operator assigns a SIC to the flight, they become a required crewmember and therefore may log the flight time as appropriate.
Another example of a situation in which an SIC is required is illustrated in the many posts on the Propilot BBS concerning various air cargo companies which employ SICs to fly small airplanes (Beechcraft Barons, for example).
Although the SIC may not be required by 135.101, as passenger-carrying operations are not being conducted, there are other kinds of operations which may impose a requirement to use an SIC.
If the operation requires two pilots under FAR 135.267 because the flight time will exceed 8 hours, then the SIC is required and he/she may log all flight time. The time may be logged as SIC when not flying. It may be logged as PIC (or SIC, if desired) when the SIC is the sole manipulator of the flight controls. See FAR 61.51 (e)(1) and (f)(2).
Similarly, when lower-than-Category I takeoffs are accomplished (less than 1800 RVR) under FAR 135, Operations Specifications (OpSpec) paragraph C57(e) requires the SIC to be aboard. OpSpecs carry the same weight as the FAR, since compliance with them is mandatory under FAR 119.5(g). Again, the SIC may log SIC time when not flying; and may log PIC time (or SIC, as desired) when the SIC is the sole manipulator of the flight controls.
Approval for single pilot operations with use of an operative approved autopilot system under FAR 135.105 gives an operator an additional option in the conduct of operations. It does not mandate that all future flights be conducted in that manner. The operator can elect to fly trips with two pilots, as is otherwise required for flight in IFR conditions under FAR 135.101, using the second in command instead of the autopilot.
Your second question asks if, under the circumstances given above, the SIC can log time as SIC when the designated pilot in command is flying the aircraft. The answer is yes, as long as the certificate holder is using the SIC as a crewmember instead of exercising the autopilot authorization. In other words, the certificate holder elects not to conduct an IFR flight using the single pilot with a functioning autopilot option, but rather conducts an IFR flight using two qualified pilots. The two pilots are then "required by the regulations under which the flight is conducted", FAR 61.51(c)(3), and the assumption is that the second pilot (SIC) will function as a required crewmember, and SIC time may validly be logged. However, if for some reason another qualified pilot "rides along" and does not function as a crewmember, then second in command time may not be validly logged.
This interpretation has been prepared by Arthur E. Jacobson, Staff Attorney, Operations Law Branch, Regulations and Enforcement Division; Richard C. Beitel, Manager. It has been coordinated with the Manager, Air Transportation Division, and the Manager, General Aviation and Commercial Division, Flight Standards Service.
We hope this satisfactorily answers your questions.
Sincerely,
Donald P. Byrne
Assistant Chief Counsel
