ArcherB said:I am pretty sure you do need to be either " IMC" or if "VMC" you need to have a saftey pilot. The reasoning is that if you are single pilot in "VMC" even though you are on a instrument flight plan you should be looking outside and maintaining visual seperation with other airplanes.
I think that's the point. Logging questions =usually= (though not always) include the unstated phrase "that counts for currency or toward a certificate or rating under the FAR"JungleJetFO said:If you are on an IFR flight plan and you shoot a non-precision or precision approach in VMC or IMC, log it. You shot the approach, why would you not log it? Think of it this way, say you do a VOR-DME approach with a 12 mile arc, would you not log it? Who cares what the weather is? Now, when you are talking instrument currency, that's a different story,
You can log it for the sake of the approach being a detail of that flight, but unless it was in actual IMC or simulated IFR with a safety pilot, it won't count for currency.teach2fly said:can you log an instrument approach if its VMC, single pilot IFR?...assuming you're IFR current and you just shot an ILS approach down to the DH (in an IFR flight plan and cleared for the approach) and full stop landing.
Actually this particular harebrained notion is supported by John Lynch's sometimes harebrained FAQ. He doesn't explain why, but the best argument that I could find that supports it goes something like this:bobbysamd said:I don't recall at the moment what he saw in the FARs to give him that hare-brained notion; it doesn't matter because it obviously flies in the face of common sense.
Timebuilder said:I'd include the fact that an SIC in a two-crew airplane can only log instrument time at all when he is flying the airplane, not as a "condition of flight", such as "night", which can always be logged.
But a CFI is neither. The CFI logging regulations don't really have anything to do with the CFI as a crewmember of any kind. I think they are pretty much a policy decision by the FAA to let CFIs log certain things simply because they are acting as an instructor. In addition to allowing career track pilots to use instruction to build time, there's probably also a general recognition that there's no better way to learn something than to teach it.Timebuilder said:If you think of the CFI as a "required crew member", or a "second in command"
If you believe you can always log "night" time "as a condition of flight", then by that same logic, you can log "instument" time.
Therefore, I didn't understand why you have no problem logging night time "all the time", but instrument time only when you were actually flying the airplane.
Really, all I was initially doing was pointing out that the FARs consider "instrument" to be a condition of flight the same as "night".
Just an FYI for the few who don't know at this stage of the game. John Lynch is with the FAA certification branch. To the extent that there really is one, he's the author of the 1997 revisions to Part 61. In an effort to standardize the way Examiners use the rules, the FAA's Regulatory Support Division (http://afs600.faa.gov/AFS640.htm) publishes a Part 61 and Part 141 FAQ. Lynch is the "guru" who answers the questions.Timebuilder said:I was referring to Lynch (whoever he may be)
A Squared said:I'm still shaking my head about that idiot JungleJetFO shooting his mouth off about logging approaches in VMC.
There it is, in IMC or simulated IMC right down to the minimums, or it doesn't count. Now, if you break out 100 feet above minimums ..... well, I think that is probably close enough, but logging an entire approach flown by yourself in VMC? Where do people dream up this crap?
Section 1.57(e)(1)(i) states that:No pilot may act as pilot in command under IFR, nor in weather conditions less than the minimums prescribed for VFR, unless he has, within the past 6 calendar months - (i) In the case of an aircraft other than a glider, logged at least 6 hours of instrument time under actual or simulated IFR conditions, at least 3 of which were in flight in the category of aircraft involved, including at least six instrument approaches, or passed an instrument competency check in the category of aircraft involved.
If you put something in your logbook that ain't right, the FAA considers it falsification
Timebuilder said:Perhaps JungleJetFO means to say that he puts on a pair of foggles to meet the requirement of simulated instrument conditions when he makes an approach without actual conditions?
