logging actual
saviboy
Hi
I flew a 3.8 x country flight with my student and I would estimate the actual portion of the flight as about 2 hours. do you guys have a more acurate way to measure the actual portion of a flight?
thanks
Try your watch and let us know how it works out. :)
Actually I know of no one who doesn't "estimate"
If you really wanted to be anal about it you could put a stopwatcharound your neck (so you could turn it on and off without looking atit) and clickety click back and forth all the way. My guess is that itwould be pretty close to your estimate. :cool:
I got to think a good faith estimate is more than sufficient. That's what i've done on flights, and would be comfortable defending that approach and my estimates.
You better use your watch or your hobbs meter since the FAA may getcha on that +/- .1 where you may be off. It is extremely important to be exact as possible, God forbid you should be off juss a .1 or so off. In a perfect world that is, use a good faith estimate as the above poster mentioned. You are not going to be exact even if you did use that watch or meter, in no way is this going to come back and haunt you unless you should up to an interview with 1500TT and 1100 being in actual imc, that may raise a few red flags. If your flight was 3.8 and you think that 2 of it was in actual then by all means log the 2 hours of actual imc in your logbook.
3 5 0
