Well this is another one of those logbook pro posts.
Since things keep on changing, I want to get a Treo and just wondering which one and which operating system to go with. From you guys with experience I sure hope you can help out.
650, 700, palm, windows etc...???
The only change I don't like is the new sync operation only grabs the first tail # when you are syncing one line per day to the master log. The old version would create a new line for each new tail # when swapping aircraft during the day.
Example, can't add a contact from a number that calls you. You have to add the name first and then remember the number and copy it over.
...Or did you mean that there used to be a feature that would put everything into one line untill there was a new tail #?
