Company: Airport Terminal Services Product/Service:
Location: San Diego Int'l Airport Required Travel: None
Job Type: Part-time Employment Type: Permanent
Description:
Performs ground handling duties around aircraft for airline customers on the ramp. Duties: 1. Ensures a safe work environment by following all ATS rules and regulations regarding the workplace. 2. Marshals inbound aircraft into the ramp area of assigned gate. 3. Loads/Unloads passenger baggage, cargo, and mail from aircraft bins onto bag carts while the aircraft is parked at the gate. 4. Delivers loaded bag carts using tugs to bag room and unloads bag carts onto conveyor belt, which will deliver the baggage to the passengers. 5. Delivers bag carts of mail to airport post office and picks up loaded carts for outgoing flights. 6. Services aircraft lavatories. 7. Grooms aircraft passenger cabins between flights. 8. Services aircraft water tanks to ensure there is enough drinking water on the plane. 9. Stocks aircraft with needed supplies for lavatories or galleys. 10. Loads bag carts in bag room with baggage from the ticket counter for outgoing flights and delivers them to aircraft. 11. Pushes back outbound aircraft from the gate area. 12. Tows aircraft to remote areas at the airport as required. 13. Performs FOD walks in the ramp area between flights. 14. Ensures necessary ground equipment is available in the ramp area and bag room for upcoming flights. 15. Performs assigned administrative duties – GSE fluid inspections and appearance, FOD walks, washing equipment and removing trash from ramp area as needed. 16. Other duties and requirements as necessary.
Requirements:
Qualifications: 1. Minimum of 18 years of age. 2. Possess a valid driver’s license and maintain a clean MVR. 3. Able to lift up to 70lbs. 4. Work outside in all types of weather. 5. Must be flexible to work various shifts and days
Company Benefits:
parking and flight benefits
Contact Information:
Karey D Erb [email protected]
Phone: 619 298-9529
San Diego Int'l Airport Alaska Ticket Counter
San Diego CA92101
US
Preferred Response Method:
e-mail to Karey or by phone contact Truck Easley
