I believe I have a reasonably good understanding of CSUs and variable pitch props and how they relate to twins and singles but the more I think about it the bigger the hole I dig.
My question is, following a confirmed engine failure in a typical light twin (PA-44), what exactly (mechanically) does pulling that pitch lever all the way back do? Is the only difference between a very low RPM setting and the feather position that in the feather position the feathering locks are inhibited from engaging? So basically does pulling the prop to feather stop the feathering locks from engaging and allow the counterweights, nitrogen and spring pressure to drive the prop to feather?
When taught to test feather in the runup bay the procedure was 1500 RPM then pull the pitch lever into feather, ensure it can travel all the way then straight back to fine pitch. If indeed all the feather position does is to inhibit the feathering locks from engaging should the correct procedure be to check RPM can drop below 950 the return it to fine pitch?
Thanks in advance
Thanks in advance
