ksu_aviator
GO CATS
- Dec 1, 2001
This is all you need to know
To enter the manuever, start out straight and level, in perfect trim, and at a specified airspeed. Begin by banking only 2 deg and then adding back pressure to the controls. Do not grip the controls, doing so will cause you to over control, two fingers will be all you need. Continue applying back pressure until the airplane is about 12 deg pitch up (changes slightly with each airplane type). Amazingly, by doing this the airplane will have turned 45 deg and banked to about 15 deg.
Continue adding back pressure as the airplanes nose begins to dive, again amazingly as you do this the airplane will roll into a 30 deg bank at about the 90 deg point, and with some practice and timing you'll be nose level too.
As the airplane's nose passes through the horizon at the 90 deg point, begin very gradually pushing forward on the control column and ad just a touch of roll out. Your goal is to pitch about 12 deg down. If your pitch is too shallow you will come out of the manuever high or slow and if your pitch is too steep you'll come out of the maneuver too low or fast.
The time between the 135 deg point and the 180 deg point is the longest. Be "Lazy" and don't roll out too fast, that is the most common error in this whole maneuver.
Repeat the process for the opposite direction. A left turn will require less rudder than a right turn. And finally, remember its not possible to do this maneuver and have the exact same airspeed at the exact same altitude without adding power. That would be perpetual motion. But the FAA requires the manuever be performed on the checkride without adjusting the power. Apparently they don't know about physics.
