MauleSkinner
- Sep 4, 2005
Just so we're on the same page, I assume you wouldn't consider the landing assured if you couldn't see the runway?Blackjet said:Well, landing assured does not mean the runway can be seen. That is called runway in sight. I dont think any instructor has told you or anyone else that "landing assured means runway can be seen. Landing assured is when you can pull the power to idle or loose all propulsion and make the runway, not just the field. For example, when flying a single engine approach with an aircraft with 2 or more engines, the last increment of flaps is usually held until landing is assured. That would mean just about at the runway. That is where my confusion was as to his situation.
I guess accuracy in terminology is important
David
