wingnutt
...recognize this?
- Mar 31, 2002
ah yes, its that time of year...
for those that havent seen the conversation on the other board, im interested in your thoughts about icing. mostly the thoughts seem to center around "known" icing. i would post this on the general board, but im not interested in part 91 or 121 ops...only 135.
heres my theory thus far. "known" icing, in my mind, relates to pireps. but i have heard that in lieu of a pirep, or even when there is a pirep for no ice, forecast conditions rule. now then, we all know that loopholes are looked for in Part 135 ops, i mean, who has never blasted thru a low layer in order to keep from having to file to get out of class B without that annoying STAR
anywhoo...i was talking to another operator and he was arguing the fact that we cannot take off into an area of "forecast" icing (which for all intensive purposes means an Airmet). this is bogus i say. forecast only means that the conditions are conductive to icing, not that there will definately be icing. heck, if we were not allowed to take off into forecast icing, all 135 ops should have been grounded for about 2-3 days in the state of Texas about 2 weeks ago, except for those certified into icing condition of course. which brings up another point...
"certified" or "placarded". the other board mentioned something to the effect that as long as your aircraft wasnt placarded against flight into "known" icing conditions (mostly older aircraft, i believe), you are fine to take off and fly (some restriction, but i dont recall). then if you are placarded against it, one can still fly, as long as when the icing condition is entered, one exits it as soon as possible.
now then, ive talked to one of the "older, wiser" pilots in our line of work, and he tells me there is a reg that will allow you to continue a normal flight, even if there is a pirep and/or Airment, as long as you have solid evidence to believe otherwise. hes going to dig around and bring me the reg, but it could be awhile.
needless to say this is all moot if the FAA sees you land looking like a popsicle, and hes had a bad day...your probably in a world of trouble.
...confusion abounds
