Jaa Atpl
fishguy79
Active member
Looking for information of obtaining JAA ATPL. I know there are 14 written exams but not much else. Any good sources of information on how to do it and what it costs?
you can do a correspondence course with a company like naples air center in fla,there are others but i cannot think of them right now.check out their web site. that will give you a good idea of what is involved.
www.pprune.org/forums has a lot more information than is available here. It's a UK based board, similar to this one.
Use the search function & you'll find a **LOT** of information about the JAR ATPL. Otherwise browse the 'Wannabe's' forums.
One thing I would add would be to contact the aviation authority in your country to see what exactly they accept in terms of training. Cover all your bases. The training is not easy and with the dollar so low, it can get expensive very....very quickly. Good luck
Fishguy,
[font=Verdana, Arial, Helvetica, sans-serif] [font=Verdana, Arial, Helvetica, sans-serif]You are obviously experienced so you should apply to the CAA for a formal assessment using [/font]http://www.caa.co.uk/docs/33/FORSRG1103.PDF
[/font][font=Verdana, Arial, Helvetica, sans-serif]The qualifying criteria are[/font][font=Verdana, Arial, Helvetica, sans-serif]
[/font]
[font=Verdana, Arial, Helvetica, sans-serif]1. more than 3000 hours total time on aircraft of more than 30,000kg AUW[/font][font=Verdana, Arial, Helvetica, sans-serif]
2. more than 1500 hours pilot in command on aircraft of more than 30,000kg AUW
3. type rated on an aircraft of more than 30,000kg AUW
4. more than 500 hours total time on the aircraft above
a
[/font][font=Verdana, Arial, Helvetica, sans-serif]ble to complete a flight test on the same aircraft
[/font]
[font=Verdana, Arial, Helvetica, sans-serif]When you have completed the assessment form you need to send it or take it to the CAA with your original licences and log books. The CAA will tell you that you need to pass two written exams, Human Performance and Aviation Law, and pass a flight test on the aircraft you are rated on. The flight test is referred to as a skills test, it is part handling check and part IR renewal check.
[/font]
[font=Verdana, Arial, Helvetica, sans-serif]Regards,
[/font]
[font=Verdana, Arial, Helvetica, sans-serif]IF
[/font]
