UA-RESURRECTED
Does this mean I failed?
- Nov 3, 2005
Murdoughnut said:Check out ... http://www.leftseat.com/baggish.htm
Good luck finding any of these alternative tests, though. Your best bet is to go to a university optometry clinic. They are more likely to have a wide range of tests. I contacted Ohio State and they said they offered the Farnsworth Lantern and Dvorine 2nd edition. I found a Dvorine test booklet in a college library and was able to see far more of the test numbers than I could in the standard Ischihara.
I later came to find out, however, that because I passed the signal light gun tests several years ago, I don't have to test for colorvision in the future when I go to get my med. They gave me a letter of demonstrated ability, or something along those lines.
Good luck!
UA-RESURRECTED said:Thank you. The only reason I'm holding off on the light-gun test, is because apparently you get a brand-new medical by taking an alternate test.
