Interview with Allegiant
indynomore
Member
I'm going to interview with Allegiant on the 11th. I live in MCO. Does any Allegiant guy out there have an idea how long this interview could last for. I'm trying to make my own travel arrangements. Any heads up on the interview, other than the ones in this forums will be appreciated!!
For some reason, they don't fly between SFB, and LAS. Not a businessman, but seems that would be a hot market.
You guys know what are the real chances I'd get SFB right away and if not how long till I do! I've heard opinions from right away to no way.Also is seniority base on D.O.B?? Thanks guys...
Seniority is DOB in the class. There will be some movement in March for a new base. Between that, expansion and upgrades there shouldn't be a problem getting SFB. Even if you don't get SFB, you should be able to get one of the other FL bases to hang out in until a SFB slot opens.
SFB - LAS wouldn't work in the MD80, doesn't have the range.
