If you are landing and going through a micro burst you will get an increase in headwind followed by the wind going 180 degrees on you and suddenly becoming a tailwind. This results in the mass having to be accelerated, this can only be done by increasing thrust, the bigger the aircraft the harder they fall in this situation.
Landing data is based on crossing the end of the runway at 50 feet with a touchdown at the 1000 foot mark plus I think 60% again I would have to look up the exact numbers. Wet runway requires 115% of the above number. Most 121 operations use weight as the determination of the usable runway. When you land and do not touch down at the 1000 foot mark you are using up your 60% of fundge factor which is factored into the landing distance. Most landing data is based on touchdown at 1000 foot mark, max braking, no reverse, so if you don't use the brakes again you are using your 60% fudge factor. At our airline we have a requirement that anytime the runway is shorter than 7000 feet we use autobrake 3 and 40 degree flaps. Addtionally we have to go to the QRH and determine the exact amount of runway that will be required for the conditions. This mental process inforces the fact that on a short runway we must land on the first 1000 feet and get the aircraft stopped. Smooth landings are for long runways, of course the real top guns and "grease it" at the 800 foot mark and get it stopped in a hurry.
