Guppydriver
- Jan 21, 2002
Guppydriver said:Anyone have any info on the Intel flight department? Couldn't find any aircraft listings in the NBAA guide and contact in the guide is a customer service type.
chicnaso said:Intel Shuttle is now run by ADI out of Michigan. EJM lost the contract in July of 2004. Starting F/O = $35K/yr. Starting CPT = $60K/yr. Long days but depending on your domicile you only fly 2-3 times/wk. Weekends and Holidays off. You'll never upgrade in Oregon/Washington/or California. Only chance is Arizona where there has been high turnover. Not the best corporate job but good if you want to be home every night.
I'll answer more questions as they come.
Good Luck!
chicnaso said:I think they got the CG problems worked out. They have ballast available if necessary. The loads are high enough that they typically don't need it.
The only hiring I'm aware of is at the Arizona domicile (Phoenix - Williams/Gateway). I don't anyone will ever leave Washington or California. It's unlikely for Oregon, too.
Morale is at an all time low. Many reasons for this but primarily management.
Hope this helps.
chicnaso said:They went from the Bandits to Beech 1900C's and a Jetstream. They replaced the 1900's with EMB-135 RJ's and the Jetstream with a 1900D. They have six RJ's and got a 1900D for Olympia, WA. Strips too short for a RJ. The trips are between MHR, SJC, and HIO. The Oregon and Arizona pilots fly the same basic trips between their domiciles. OLM only flies between there and HIO. Still long days.
