T teewilly New member Joined Nov 2, 2003 Posts 3 Feb 16, 2004 #1 of 3 If I have done a multiengine IPC does that cover my single engine privilages as well?
A avbug Well-known member Joined Dec 14, 2001 Posts 7,602 Feb 16, 2004 #2 of 3 Yes. 61.57(d)(1)(i) stipulates that the proficiency check must be in the same category of aircraft. In this case, airplane. You are covered for single engine airplanes and multi engine airplanes, if you already hold instrument privileges in each class of aircraft.
Weasil Well-known member Joined Jul 19, 2003 Posts 752 Feb 23, 2004 #3 of 3 That's correct. IPC's are for Category (not class) of aicraft.
