nosehair
- Sep 22, 2003
Sir, I have seen you suggest this idea that an ICC does not require a signature before. I have to assume that you are making this point because 61.57(d) does not use the words "logbook endorsement" as does the Flight Review reg, 61.56.UndauntedFlyer said:Nowhere does it say in the FAR's that an ICC must be signed by the person who gave the check.
61.57(d) does say, in part:"...may not serve as pilot in command under IFR...until that person passes an IPC...required by the instrument PTS."
So, as you have already said, it was not an IPC because was only some approaches. It probably did not meet the IPC PTS requirements. The original poster probably does not know that the IPC requirements are mandated in the instrument PTS, but that is another story.
Back to the IPC signature requirement. You might win the case that a signature is not required by a specific regulation, but how do you show that you passed by an authorized instructor, as the regulation requires?
O, yeah, you could just have the authorized instructor call the FSDO and verify that he was actually on board and that you did pass; is that your thinking? What are you thinking? ...and, of course, in this case, the authorized instructor would probably say, "No, I was not doing an IPC, it was only an interview. It wasn't even dual instruction."
That is why you should not write stuff in a logbook concerning dual instruction unless the instructor himself knowingly signs for it.
Also, 61.51(g)(4) says: "A flight sim or FTD may be used by a person to log instrument time provided an authorized instructor is present."
I think you might be legal to log that as time without a signature, but you would have to be able to produce some kind of record or proof that an instructor was present.
I'm just saying, Sir, that it promotes problems, mis-understandings, and can be down right unsafe to indicate that you can log sim time without an instructor's signature. Especially an IPC. No matter how you might like to twist the regulation.
