Yes on both... When I was a Flight Instructor the school I worked at didn't have a complex single, but we had a twin... So most people got their MEI first and then got their CFI-A and CFI-I as add-ons... We also had some Students do their CFI-I first, then the MEI then the CFI-A...Steveair said:Can you get your CFII without holding a CFI? Why/where regs?
Can you get your MEI prior to your CFI?
(emphasis added)(1) A pilot certificate and flight instructor certificate with the applicable category and class rating; and . . . .
(c) Instrument Rating. A flight instructor who provides instrument flight training for the issuance of an instrument rating or a type rating not limited to VFR must hold an instrument rating on his or her flight instructor certificate and pilot certificate that is appropriate to the category and class of aircraft in which instrument training is being provided.
U-I pilot said:Ok, So i just got my CFI-I yesterday and something similar to this was asked of me....
If someone with a multi wants an IPC am I allowed to give it to them?
I answered yes because what I am providing is instrument instruction not multi-instruction.
There are some caveats that if he is out of IFR recency it must be VFR conditions and he must be multi-current.
All that 61.195c says is: "...must hold an instrument rating on his or her flight instructor certificate and pilot certificate that is appropriate to the category and callss of aircraft which instrument training is being provided."
Also,
The 5 hours make and model for MEI's and multi engine aircraft is only required if the training is for a certificate or a rating which recency is not. (61.195f).
Any thoughts here?
That is incorrect. Read what I wrote above. A comp check is virtually an instrument checkride these days. To perform a proper comp check in a multi per the Instrument PTS, you must pull an engine for at least one approach. To pull engines, you must be properly authorized. You are not authorized to pull engines unless you are an MEI.U-I pilot said:If someone with a multi wants an IPC am I allowed to give it to them?
