Info needed on CJ & B-200
dpilot_citation
Hey Guys & Gals,
Need some real numbers on the B-200 and a Straight CJ
Speeds
Fuel burn
Range full fuel and number of seats
Full seats and range
Any thing we should look out for.
Thanks for the help……
Dpilot
Hey Guys & Gals,
Speeds
Fuel burn
Dpilot
For the CJ
1.350-360 TAS
2.1000 1st hour then about 700
3. Not much more than 1150 miles with 1 pilot and 2 pax (no wind)
4.1 pilot and 6 pax = 700 miles (no wind)
5. New $9000 inspection (more if they find anything) required for CJ's with pilot relief tubes under the seat. Also if you find one on TAP Elite it's like buying it with new engines, no matter the time on them. You would have very little engine maint. liability.
Thanks! ekuflyer
We were at ICT service center and saw the results of the p-tube...They have the wing off of one in the corner of the hangar....They said that this was going to be a big problem for the CJ
Again thanks for the info!
B200 anyone.....Thanks Dpilot_citation
B200-
1. 270 kts.
2. 700 1st hr, then 600 each hr.
3. Like the CJ, about 1150nm with full tanks but 3 pax. (no wind)
4. Full seats about 800nm. (no wind) 7 pax
5. The range is limited because of the 12,500 max (to keep away from type rating).
Both are great planes, one is quiet, the other has more room.
