See the NTSB report below. My question is this: why is it improper use of carb heat to engage the heat while in cruise flight? I thought it was acceptable to push the heat on to check for carb ice. Should you not due this while IMC?
NTSB Identification: BFO88LA013 . The docket is stored on NTSB microfiche number 35180.
14 CFR Part 91: General Aviation
Accident occurred Thursday, January 07, 1988 in ROCK CAMP, WV
Aircraft: PIPER PA-24-250, registration: N14BK
Injuries: 1 Minor.
DURING CRUISE FLIGHT IN IMC THE ENGINE STOPPED WHEN THE PLT TURNED THE CARB HEAT TO CHECK FOR CARB ICE. HE WAS UNABLE TO RESTART THE ENGINE. HE DESCENDED INTO VMC AND TRIED A FORCED LANDING IN AN OPEN FIELD. THE ACFT STRUCK A TREE SHORT OF THE FIELD. THE PLT LOST CONTROL OF THE ACFT AND IT LANDED HARD IN THE OPEN FIELD. EXAM OF THE ACFT DID NOT DISCLOSE EVIDENCE OF MALFUNCTION.
The National Transportation Safety Board determines the probable cause(s) of this accident as follows:
CARBURETOR HEAT..IMPROPER USE OF..PILOT IN COMMAND
FUEL SYSTEM,CARBURETOR..ICE
Contributing Factors
WEATHER CONDITION..CARBURETOR ICING CONDITIONS
OBJECT..TREE(S)
Injuries: 1 Minor.
OBJECT..TREE(S)
