Up and Locked
New member
- Nov 5, 2003
In the following scenario what would be the right thing to do?
A 19 passenger turbo-prop is doing an IFR departure from a non-radar airport under part 121 rules. The weather is good VFR. The obstacle clearance departure procedure for the departure runway calls for a climb, runway heading, to 700 feet above airport elevation before turning on course.
After takeoff, tower calls, “(any airline flight) turn left to a heading of 150 degrees.” The heading would require a 45 degree hading change as the aircraft is climbing through 400 feet. Should the crew ignore the clearance and follow the obstacle clearance procedure, or should they comply? I think they should comply but I can’t find anything official to document my beliefs.
