bytheseatofmy
Member
- Nov 22, 2005
Actually, a ventury will "create" an icing encounter...as warm, moist, cloudy air has its pressure reduced by the venturi, it also cools adiabatically. If it cools enough, it will create ice in the venturi, eliminating your vacuum source. This is just like the ice created in the carburetor, btw..you just don't have a "venturi heater" to get rid of it.Wrenchnfly said:Keep in mind your venturi would also ice up during an ice encounter.
