GravityHater
 - Aug 12, 2004
On average, of course the situation will change with aircraft, traffic, weather, controllers etc.
Busy Class C terminal area and you are arriving, everyone is on the ILS. I find they usually want you going pretty fast when able right up til the FAF. These are just 'average goals for most smaller, slower, lighter turbojets'.
Below 10K you are less than 250kts; I will write "240kts below 10"
240kts all the way to "cleared approach" unless you need less for configuration.
A few miles before intercepting the loc, (just as a beginnning suggestion), a speed that does not give an ordinary autopilot fits to capture the course; usually what... below 200kts??
FAF; the gear goes out so "gear speed minus 10 or so, at the FAF"
Inside the FAF, reducing from Vle to "vref + 10" or so.
Over the fence; Vref.
I realize many companies dictate a stabilized approach and one speed inside the FAF but this is meant for an airplane/situation that is slightly more flexible.
Never seen a written recommendation in a text or received one in training so I thought, why not try to come up with one?
Thanks.
Thanks.
