Hs-125
FO4life
Going to school for Hawker 700 initial. what other aircraft if any does the type rating cover?
Unless it says 1000, I believe it covers from the viper powered basic or 1a to 800xp. There are something like 30 plus varients in the HS line. Basic ac, get it started and it will get you home. The biggest drag is the takeoff charts where you will learn the value of "D". Spend the coin, buy an Ultranav program for your computations. Or, learn to spend time in chart performance madness. You will see. Good luck.
the hawker type is hs-125 which covers all the hawkers except the the 1000 which is actually called bae 1000
and as far as filing flight plans the hawker is h25b
and the 1000 is h25c
