How do I hook up my PSP to the MFD?
COOPERVANE
Member since 1967
I need to know if anyone knows how I can hook up a PSP to the MFD of an RJ.
I got the Ipod hooked up to the Com system, now I need to get some Halo on.
I need constant stimulation and don't know how to carry on intelligent conversation. I also need deets for the bro for when I upgrade in 6 months.
Once I get my 1000 hours PIC I'm outta here. I cant fly the 88tho, cause I need screens. Does the 76 have an MFD like th RJ?
Rant over....I feel better
Just think, when on-board wireless networking gets perfected, you'll be able to fire up World of Warcraft on the EFIS
It's all ball bearings nowadays. Now you prepare that Fetzer valve with some 3-in-1 oil and some gauze pads. And you're gonna need 'bout ten quarts of anti-freeze, preferably Prestone. No, no make that Quaker State.
You're just not trying hard enough until you're able to bring porn out of the FMS.
Forget the PSP, I want to hook up a Wii and use the plane as the controller.
Talk about motion sickness......
There's an ARINC232 cable under the dash. Just unplug the green wire with the stripe on it and plug your USB2 adapter into that jack. You can get a hot power supply by tapping into the right engine fire bottle power line. It's on the Hot Battery buss so it even works when all A/C power is off.
There's a computer interface port behind the FO's seat in the CRJ for updating the FMS. Just hotwire your USB output into there, replace the database of the FMS with your iTunes movie catalog and edit the DCU system parameters so that when you're watching movies on the MFDs, you don't get all those nuisance aural engine fire and stall warnings.
MM
It must be fun to be old.
(Maybe it says something about you that those you fly with would rather play golf on the PSP than talk to you.)
It's simple, pop 4A1 and 2FE and use some old Sega Genesis jacks in their place. Who cares that you might get a runaway stabilizer. The clarity on EICAS 2 is amazing.
How do you hook up Palm Springs with Medford?:confused:
