CHI03FA138HISTORY OF FLIGHT
On May 25, 2003, at 1754 central daylight time, a Piper PA-31P, N36DR, piloted by an airline transport pilot, sustained substantial damage when it impacted trees and terrain after takeoff from runway 36 (5,150 feet by 100 feet, asphalt), at the Lakeland Airport/Noble F. Lee Memorial Field (ARV), near Woodruff, Wisconsin. The airplane was consumed by fire subsequent to the impact. The 14 CFR Part 91 flight was operating in visual meteorological conditions and an instrument rules flight plan had been filed but not activated. All four occupants of the airplane were fatally injured. The flight was originating at the time of the accident. The DuPage Airport (DPA), West Chicago, Illinois, was the intended destination.
The airplane was reported to have been flown from DPA to ARV by the pilot and pilot rated passenger in order to pick up two passengers and return to DPA.
The airplane impacted into level wooded terrain about 1/2 mile north of the departure end of the runway and left of the extended runway centerline.
A witness who is a pilot reported seeing the airplane "hardly climbing at 60+- feet just above the [runway] 18 threshold. At this point he was making some power and no engine abnormalities or prop sounds were heard. The plane was very slow with a 5 [degree] pitch up then I saw the nose leveled and I knew he was in serious trouble. I saw the plane going straight for a few more seconds then lost sight. I listened as I ran to my truck. I then heard it hit the trees and impact."
Another witness reported seeing the airplane take-off. He reported that the sound was not normal and that this is what drew his attention to the airplane. He said that the airplane sounded labored. He reported that the airplane was not gaining altitude as expected and the airplane was much lower than he was accustomed to seeing. He stated that he lost sight of the airplane due to obstructions to his view. He stated that from the time the airplane drew his attention, to the time the airplane started hitting the trees, the engine sounds did not change.
PERSONNEL INFORMATION
The pilot held an airline transport pilot certificate with ratings for multi-engine land airplanes with commercial privileges for single engine land airplanes. The pilot was type rated in Boeing 757, Boeing 767, McDonnell Douglas DC-9, and Cessna 500 series aircraft. The pilot also held a flight engineer certificate for turbojet-powered airplanes and a flight instructor certificate with a rating for single engine airplanes. The pilot's flight logbook was not recovered. The pilot served as a chief pilot for a major airline. According to airline records, the pilot had accumulated 8,524 hours of flight time in Boeing 767 and McDonnell Douglas MD-80 aircraft. An airline representative estimated that the pilot also had approximately 4,000 hours in Boeing 727 aircraft. The Boeing 727 flight time was estimated since the airline no longer maintains flight records for that airplane.
The pilot's first class medical certificate was issued on February 3, 2003, with the limitation, "Must wear corrective lenses." The pilot reported having
11,850 hours of flight experience as of the date of his medical certificate.
Training records obtained during the investigation show that the pilot received 11.0 hours of ground training and 3.0 hours of flight training in the accident airplane on October 7, 2002. The records indicate that engine-out procedures and engine-out approach and landings were performed.
The training records indicate that Vmca demonstration was not performed. Vmca refers to the minimum airspeed in flight at which directional control can be maintained, when one engine is made inoperative.
The right seat passenger was also a pilot. The passenger held an airline transport pilot certificate with ratings for multi-engine land airplanes with commercial privileges for single engine land airplanes. The passenger was type rated in Boeing 727, Boeing 757, Boeing 767, and Lockheed L-382 series aircraft. The passenger also held a flight engineer certificate for turbojet-powered airplanes. The passenger's flight logbook was not recovered. The passenger had previously served as a chief pilot for a major airline prior to his retirement in 1999. According to airline records, the passenger had accumulated 2,473 hours of flight time in Boeing 767 aircraft. An airline representative estimated that the passenger also had approximately 7,000 hours in Boeing 727 aircraft and 3,000 hours in Boeing 707 aircraft. The Boeing 727 and Boeing 707 flight time was estimated since the airline no longer maintains flight records for those airplanes. The airline representative also indicated that the passenger had an additional 500 hours in Boeing 727 airplanes as a result of flight activity for a travel club after his employment with the airline.
The passenger's first class medical certificate was issued on April 25, 2003, with no restrictions.
The passenger reported having 15,682 hours of flight experience as of the date of his medical certificate.
METEOROLOGICAL INFORMATION
The departure airport automated weather observation system recorded the weather at 1753 as: Wind 020 degrees magnetic at 7 knots gusting to 15 knots; Visibility 10 statute miles; Sky condition clear; Temperature 19 degrees Celsius; Dew point -8 degrees Celsius; Altimeter setting 30.09 inches of mercury.
WRECKAGE AND IMPACT INFORMATION
...The left wing was damaged by impact and fire. The majority of the wing structure was consumed by fire. The aileron and flap were identified. The aileron control sector was found with both cables attached. Both cables were continuous to the center fuselage area where both cables were broken. Both of the cable breaks exhibited signatures consistent with overstress. The flap actuator was found in the fully retracted position.
The left fuel selector valve was found positioned to the inboard main fuel tank. The crossfeed selector valve was found in the off position...The right fuel selector valve was found positioned to the outboard auxiliary fuel tank.
...The right propeller blades exhibited leading edge damage and chordwise scratching. The blades also exhibited bending and twisting opposite to the direction of rotation. The propeller spinner was crushed and twisted opposite to the direction of rotation.
...The left propeller remained attached to the drive gear from the engine.
No evidence of rotation was noted with respect to the propeller, propeller blades, or propeller spinner. The left engine and propeller were retained for further examination. (See "Tests and Research" section of this report.)
Several tree limbs and tree trunks were found in the immediate vicinity of the wreckage that exhibited diagonal cuts. The cut pieces of trees were found predominately on the right side of the wreckage path.
On-scene examination revealed no anomalies with respect to the airframe, right engine, or right propeller that could be attributed to a pre-impact discrepancy.
MEDICAL AND PATHOLOGICAL INFORMATION
The results were negative for all tests performed.
TESTS AND RESEARCH
Examination of the
engine's internal components revealed no mechanical discrepancies that could be attributed to a pre-existing condition. No evidence of a pre-impact failure was found.
Examination of the left propeller ...found no condition that would have prevented normal propeller operation.
The Powerplant Engineer's Factual Report of the engine and propeller examination is included in its entirety in the public docket associated with this accident report.
The "Before Take-off" checklist contained in the FAA approved Airplane Flight Manual (AFM) for the PA-31P includes a line-item to set the fuel valves to the inboard tanks. The AFM further states in the section titled "Systems Operation And Checks";
10. FUEL MANAGEMENT
a. Inboard tanks must be selected for take-off and landing
b. Inboard tanks may be used for all phases of flight (takeoff, climb,
cruise, descent and landing)
NOTE
Since inboard tanks must be used for landing, it is essential that
fuel usage be planned to retain a reasonable quantity of fuel in the
inboard tanks (in the event of a balked landing) for go-around and
subsequent normal landing.
c. Outboard tanks may be used for climb, descent or level flight when
outboard tanks are more than 1/2 full. Outboard tanks may be used
only for level flight when quantity is 1/2 or less.
The straight line distance from DPA to ARV is 287 statute miles. According to the ARV airport manager, no fuel was obtained for the return flight from ARV to DPA.
