Help w/research paper!
outdoorsguy
Active member
I need to choose a airplane that has a particular design feature that is notably different from others of the same period. The feature can be a aerodynamic feature, a stability and contol feature, a performance feature, or any other identfiable feature that is unique. The paper can be anywhere from 4-7 pages...so I need to be able to get some research from more than one source.
Any Ideas????
Any Ideas????
Piaggio 180 comes to mind, or anything by Burt Rutan.
Beech Starship? Composite, canard, pusher props, early glass cockpit.
He-178, first turbojet
DM-1, first delta wing
N-1M, early flying wing
X-15, rocket plane
U-2, high altitude
SR-71, high speed, gee-whiz hybrid ramjet engine
Just for starters. Plenty of other firsts and one-off experimental planes, as well as examples of production planes fitted with experimental systems, like fly-by-wire testbeds. Are those acceptable, or are they looking for planes that went into production as-is with their unusual-for-their-time features?
How about the Helio Courier:
Automatically extending leading edge slats, spoiler assisted roll control. All quite revolutionary for a GA airplane at the time. Still fairly unique, even today
Ercoupes might be cool. Interconnected yoke/rudder for easy crosswinds, canted engine for reduced p-factor, almost impossible to stall, I imagine in the 40s or whenever it came out those were pretty significant advances in improving safety.
epic! said:
how about that irianian flying boat thing
He said "airplane", magic flying carpets don't count.
outdoorsguy:
This whole thread is B.S., pick up a book and get off the computer, lazy bum. Go do your own homework.
Unless it's got a nuke strapped to it.
How about the Cirrus parachute system. Cirrus has sold a lot of airplanes due in no small part to the chute and it's saved a hand-full of lives. Many ultralights had a parachute system before the Cirrus, but Cirrus took the design feature to the mainstream.
The flight manuals are online and would provide a lot of infomation. Find a couple of article on the history of the parachute and you've got a paper.
http://www.cirrusdesign.com/serviceandupgrades/pilotoperators/
No, various forms of FBW were played around with as far back as the 40s, first fitted to the Avro Vulcan I think. Not sure if they were all like that, or only experimented with in a few planes as a test bed.
outdoorsguy said:
I need to choose a airplane that has a particular design feature that is notably different from others of the same period. The feature can be a aerodynamic feature, a stability and contol feature, a performance feature, or ...
Any Ideas????
Lockheed Tristar DLC system; elements of all three above. 30 minutes of Googling ought to get you the info...
Hmmm maybe the most prolific trainer ever..and cutting edge some 50 years ago..when everything else had a tail wheel...it is......drum roll...the Cessna 172
outdoorsguy:
He just asked for suggestions. I see nothing wrong with that. It's not like he wants us to write the paper. Once he gets a good idea, then he can do the research and the paper.
As far as my suggestion, how about the first flying wing. Unfortunately, I don't remember the designation off the top of my head.
Here's some more:
Helios (the solar powered flying wing thing that NASA built a year or so ago)
AVRO Arrow (canadian fighter that was scrapped, but at the time far exceeded the known envelope)
Citation X (for it's 45 degree swept wing and high Mmo)
Any of the Rutan/Branson/Fossett projects.
Any of the unmanned aircraft (UAVs) such as the Global Hawk.
How about the Skymaster, C-336? Center-line thrust, pusher prop, boom tail, fixed gear, and hauls a truckload. There is one converted to a turbine engine.
Ercoupes are unique, they were used to test JATO units way back when. The test pilot for the first flight quit after the first flight.
767/757, first with a standard cockpit and dual type rating, yet one is a narrow-body and the other a wide-body. Pilot's have to check their bid sheet to see what type they are flying that day.
A Mooney has a moveable vertical stabilizer. A warrior has a moveable stabilator. Basically, each aircraft has a unique trait to it, even the vernable Cessna 150.
Fly SAFE!
Jedi Nein
