"heavy" callsign usage
time builder
I had a debate with another pilot about what constitutes a "heavy" aircraft. I thought it was pretty cut and dry with the definition in the glossary: 255,000+ MGTOW capability.
On the other hand, my friend found some wide body fliers who sided with him, that it depends on your weight while flying, thus many military tankers, cargo wide bodies, etc. will occasionally omit "heavy" from their call sign.
Is there more to this? Are they just being lazy, or running out of breath by the end of their transmission? Or is my friend on to something?
Aircraft capable of taking off at weights greater than 255,000 pounds, regardless of actual weight.
So, do you know many guys who don't include "heavy" in their call sign? Are they being lazy? Figuring it doesn't really matter that much anyway? Trying to keep their calls short to avoid congestion on the radio, kind of like GA guys only use the last three digits in subsequent transmissions to ATC after using the full call sign first?
But it is only used on ground, twr, and app/dep...not required in transmissions with centers...normally, that is.
Yeah, once you leave terminal airspace, the separation standards increase anyway, don't dey?
-mini
Isn't the b757 considered a "heavy" now (due to wake turb. reasons)
The 75 is treated as a heavy as far as seperation standards and what not, but they are not otherwise a heavy and therefore do not use that as part of their callsign.
That's what I'm saying..There was a 75 in front of us for t/o, and they called themselves "heavy". I questioned the guy I was flying with about it, and he didn't know either. I agree with you; I thought they were just "treated" as a heavy for seperation, but didn't actually use the term heavy in their callsign.
Only the 757-300 gets the "heavy" callsign . . . the more-than-standard separation for the 757-200 is provided without the use of the heavy callsign
Now, interestingly enough, all the time at EWR I hear somebody come on and say this, basically:
"Continental 355 Heavy, cleared for takeoff"
"Continental 355, cleared for takeoff, actually we're not a heavy today."
So either the pilot is mistaken, or else in the "real world" ATC makes a distinction. But you are right: the pilot/controller glossary clearly says it is capability.
So either the pilot is mistaken, or else in the "real" ATC makes a distinction. But you are right: the pilot/controller glossary clearly says it is capability.
Why don't they just make it easier on everybody and call the 757 a heavy. I tend to be more conservative anyway, but it seems to reason that if pilots and controllers are questioning if today's particular b757 flight is a heavy or not, then that's too close for me.
I've heard that wake turb behind a 757 is dangerous regardless of the fact if it's fully loaded or if it's light so they should go ahead and just call it a heavy.
Someone correct me if I'm wrong, and to confuse the issue a little more, I believe ATA operates (operated?) a few specially modified 757-200's with a MGTOW of a little north of 255,000#. They use (used?) the heavy callsign.
757-200
Brett- I think you're right about the ATA 757-200's. I was in the conga line at LGA the other day and they cleared an ATA 757 "Heavy" for takeoff. I looked extra hard to make sure it wasn't a -300 and it wasn't. I know your run of the mill Delta/United 757-200 tops out around 230,000 MTOW. So they must have a mod on the 752 to make it over 255k. Interesting.
Because than they'd have to re-write the rule book and start listing exceptions to the rule... which is more complicated. That's what I love about the airlines, NOTHING is that easy... they take something that should be relatively straightforward and make it the most complicated POS one can fathom.
Okay, here is the no BS on the Heavy B757-200. There are a few, not many B757-200's that gross out at 255.5K. I can can tell you the N756AF is a 255.5K airplane and N757AF is a 255.0K airplane. Just to keep it simple, the crews use the Heavy term for both aircraft. The fear was that someday someone would tip over behind one of these airplanes and having not used the Heavy call sign would have incriminated the flight crew. Easier to say Heavy every time as opposed to say, "gee what airplane am I in today"? End of story.
It is laziness, on my part at least. Including the heavy callsign doesn't make anyone else, other than a controller who already knows I'm a heavy, do anything different. If you are waiting behind me for takeoff, you can see I am a heavy, if enroute and our paths cross, ATC will move whomever to get required seperation, etc etc.
Dr Procs correct for the rest of the world, but not the US, or Canada. The US requires that heavy is used for all communications, and Canada only requires it for the initial call. The rest of the world uses ICAO rules, so you only use heavy with approach and tower.
If I don't use it in the US, its probably because I've been in working in Europe, and just forgot where I was.
I've sometimes flown trips that sometimes swap a 757 for a 767. The flight number is the same but one is heavy and one isn't.
Here's the skinny
The Heavy call sign is used by all A/C that are certificated north of 255,000 including 757's due to the wake turbulence issue with those aircraft, regardless of the current weight of the A/C, IE if your on a ferry flight and are light as a kite you still use the Heavy call sign.
It is only used for tower, approach and departure.
It is basically a backup reminder for the controller ( as its already designated on your strip) to give adequate separation. Center controllers give everyone the same separation so no need for the Heavy call sign.
It also helps the pilot behind you adjust accordingly to stay out of your wake zone, IE flying one dot high or slowing down.
Hope this helps.
I will disagree with Sampson on this issue. In the US, you must use Heavy with all calls, tower, ground, clearance, appoach, departure, and en route controllers. If you forget often times they will respond to you with the heavy call sign (or on a clearance frequency they will ask if you are heavy sometimes).
In Canada when you check in with a facility you will make the initial call with the Heavy callsign, thats it, you don't need to tell Moncton you are heavy every call.
In Europe, and the rest of the world I do agree with Sampson, the call is only for tower, approach and departure. They are the only ones you will use the heavy callsign for.
F&B
Sampson said:
It also helps the pilot behind you adjust accordingly to stay out of your wake zone, IE flying one dot high or slowing down..
Another instance comes to mind where a captain told me to waive the wake turbulence advisory when we were given "position and hold" after a departing learjet. Our plane was larger, so not much risk.
Sure enough, the controller cleared us for takeoff right away. If it were a "heavy" we could not waive the advisory, from what he told me.
-ATA's 757s are certified heavier than standard 75s, thus the "heavy" call sign. -300s are the same.
- As for non-heavy 757s, they get there own classification for wake separation. Heavys get 5 miles in trail, 757s get 4 miles on take-off.
As for the use of "Heavy" in the call sign, only in the terminal area. No one gives a sh*t how much you weight in the flight levels, in trail spacing is always the same .;)
I agree with you 100%, but why do we always hear people calling Center at altitude using "heavy" after their callsign when we're at FL330?
The people saying "heavy" with the center are just uninformed I guess or lazy. "Heavy"is not used in most of Europe the ME or parts of Asia that I have flown in.
Do none of you have a hobby? Two pages and 28 posts about the heavy call sign.
F&B
What he said is correct basically right out of the FOPM.........
The Polish airlines flight flies every day from Chicago to Warsaw as "a lot too heavy." Lott airlines flt 2 is a B767.
