Hawker 1000 type rating
Capt1124
I have searched this but not found an answer- does the Hawker 1000 have a different type rating, or is it the same as the 800?
Major differences are no "fuel cocks" in the 1000, T-handle shuttoffs that control the FADECS. BAE-125(1000) compared to the HS-125 (A1A-800XP) Seperate Types._
This is rediculous that the FAA required a separate type for the 1000. I fly the 1000 and 800XP and they are virtually the same airplane except for the engines (FADEC controlled) and various other switch placements.
I'm typed in the Sabreliner and there is a HUGE variance between the 40-model and the 65. Much like the lear types.....
What's really amusing (I have both hawker types also) is that the hs125 type will cover an absolutely enormous spread of hawkers, from the 400s to the newest. Straight vipers to the latest honeywells but the 1000 is a different cert.
Going from an XP to the 1000 was relatively painless, I can't imagine an XP to a 400 with no type change.
No kidding. Try going from the 65 to the 80. Totally different animal, but oh well, the feds made it a common type.
First the MANUFACTURER puts their input and recommendation on how much different a new aircraft is compared to their similar aircraft. Then, a committee of industry (read manufacturer and experienced industry operators) and FAA people come up with the Type Certificate Data Sheet - listing how common an aircraft is to what ever the MANUFACTURER has built. REMEMBER that the Manufacturer wants to have a common type to better sell its aircraft.
After the TCDS is completed the Flight Standardization Board decides what training is involved for a common type rating with what differences training is required. THE FSB is also made up of industry and FAA people.
Does it always make sense; I don’t think you can get the groups to agree on much. So it is a compromise.
Therefore, IMHO your comments about the FAA and the process are uninformed.
The link to the TCDS:
http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgMakeModel.nsf/MainFrame?OpenFrameSet
It sure doesn't make sense. I have one type rating that allows me to jump in a Lear 23 and a Lear 55c. And I'm not aware of any mandate by the FEDS or "industry people" that I have a lick of differences training.
Same can be said for many of these "common" type ratings.
Ultra, when you go to your next recurrent training ask the training people if you can see the FSB report for your aircraft. Or if you have access to OPSS (automated OPS Specs) you can get a copy there. It is somewhat like watching paint dry but for training people is is full of what is required to be part of the training for a series of aircraft.
The report will list the training differences for each aircraft in the type. For each Master MEL, TCDS, or FSB change, included in the committe are a number of manufactures, experienced operators, "intrested parties", and FAA inspectors with FAA engineers (some engineers are Inspectors also). The groups meet when one party in the group recommends a change or at some what "regular" schedule.
It is a process.
edit: For "differences training" some is required by insurance, or if 121/125/135 etc. In your case I would agree.
Interesting stuff JAFI...you learn something everyday....
So..let me put this to you....
What FAR covers 'differences' training for common types?
To use my previous example. I go to school and get a LR-Jet type rating by attending, for expample, Lear 23 initial.
Then someone asks me to crew that snazy LR-55c. The FAA says I can act as PIC on both. Where in the regs do they cover off the differences training?
Is the Hawker 1000 rating backwards compatible with the 800 or other HS1-125s?
I'm looking into a job flying 1000's and it would be much more attractive if the type applied to other Hawkers. If it only allows you to fly the 1000, a rare airplane, it's not a very valuable type to have.
As far as I can tell the -1000 has a stand alone type rating (from the type rating list Order 8900.1):
Raytheon Hawker Corporate Jets
(Also see Hawker Siddley)
BAE-125-1000 - - - BAE-125
DH-125, BH-125, HS-125 Series (except -1000)
Hawker Siddley 125 - - - - HS-125
The FAR requirement for differences training - I guess you mean only flying part 91? If you go to a part 142 school they have to have an approved program. they have differences training, it may cost more and I must look for the FAR that requires it. I mostly work with companies that are 121/125/135 or their insurance company requires it. I need to keep looking.....
What FAR covers difference training ??
91K, 135, and 121 have the requirement. If you are just part 91 - the FSB report (Flight Standardization Board) only "suggests" that 91 operators have differences training.
Gives you that warm fuzzy feeling, doesn't it.......
