I'm tuning up my aerodynamics knowledge for my checkride and I came across a question that I haven't been able to find a solid answer for in my text books.
How does gross weight affect the IAS you want to pitch for in a power off glide (best glide speed)? So far, each of the few POH's I have read only list one Vglide for that make/model. The only reference to this specifically that I can find is in the Handbook of Aeronautical Knowledge, page 1-24 on Forces in a Glide. It states that variations on gross weight do not affect glide angle provided that the optimim IAS for "each gross weight" is used. Then it says that the fully loaded airplane will sink faster, but at a greater forward speed (ground speed) and reach the ground faster, yet travel the same distance as the lighter airplane. This seems to say that as your plane is heavier, you would pitch for a higher Vglide IAS.
But later it states that the higher airspeed corresponding to the increased weight is provided automatically by the larger component of weight acting along the glide path. This seems to say that you pitch for the same VGlide IAS regardless of weight, and your groundspeed will vary based on weight, but your IAS will not.
So I'm confused. I've read all my other sources and none of them cover this in enough depth. Do you pitch for different Vglides based on your weight, higher IAS for higher gross weight? Or do you always have only one IAS for VGlide, and the ground speed variation based on weight is the only thing that changes?
Any insight would be appreciated
/Dave
PS, upon further review, there is a line that states the speed for L/Dmax will vary for different airplane weights, but it's doesn't specify if this is IAS, TAS or even ground speed, to which the glide angle really depends on. Still confused
/Dave
