PC12Cowboy
Berry Beery Bad
- Nov 6, 2003
MORA and Grid MORA refer to IFR charts. MORA gives obstacle clearance 10nm either side of an airway for mountainous and non-mountainous terrain (1000/2000ft). Grid Mora gives 1k-obstacle clearance below 5k and 2k above. This number located inside a lat/long grid and is either magenta for alt. above 14k or green for alt below 14k (I think I’ve got the colors right). On a VFR chart that number in the grid is called the MEF (max field elev.). It provides 100ft above man made objects and 300ft above natural objects rounded up to the nearest 100ft.PC12Cowboy said:MORA and Grid Mora which charting uses this and whats its definition???
DC8 Flyer said:Its been a while, forgive me it its not 100% correct.
Grid MORA (minimum off route altitude) on VFR sectionals shows the highest altitude of an obstacle, rounded up a 100 feet or so, in that grid. This is the one NOT to use as a minimum altitude.
