chperplt
Registered User
- Nov 25, 2001
Check this out
What a tool
Lightweight, pocket-sized, and all plastic, Knee DefenderTM is easy to use – putting you in control when there is no legroom to spare and you need help dealing with an aggressive seat recliner.
A photo of Knee Defender is shown above. At right is a picture showing you how to put it to work:
First, place your Knee Defender on either arm of your lowered tray table – at the top of the arm, where it meets the table (1). Your Knee Defender simply straddles the tray table's arm, with one leg of the device on either side of the arm.
Then, slide your Knee Defender down the arm of the tray table until it is snug against the seatback in front of you (2).
Your Knee Defender is now in place. If the person in front of you attempts to recline, Knee Defender will take the hit.
Whether you are intent on protecting yourself from being crunched, want to maintain enough room to do some
in-seat exercises, or just want some warning so you can move your computer before the seat is reclined, Knee Defender "works like a charm."
In general, the closer your Knee Defender is to the seatback, the less the seatback will be able to recline. If you need to prevent as much reclining as possible, then push your Knee Defender up tight against the seatback.
On the other hand, if there is enough room for you to allow the person to recline partially, you can often set your Knee Defender slightly away from the seatback to make that possible.
Knee Defender, with its specially shaped groove, was designed to work with a wide variety of seat and tray table designs. However, not every design could be accommodated, especially those used on commuter planes and even on some jets. For additional information about this and other questions about using Knee Defender, click here to link directly to our related FAQ pa
What a tool
