Gleim Written Software
BoDEAN
Cabo Wabo Express
Curious on those who use it, how do you go about tackeling it? So you strickly take standard tests over and over? Or do you go through all the outlines?
Just curious on how you get the most out of this software when studying for the writtens
by specific module
I found that the easiest way was to select "custom study" and then select "gleim specific module(s)".
Some modules are very small depending on the test you are taking. Select one or two modules, keep it around 20 questions. Do it over and over until you get 100%. Then select some more modules. When you have the material all covered take some practice tests in the format that your testing center uses.
good luck (hint, during the test you will find that you won't even have to read the question, you will see the correct answer)
Thanks.
You think after taking a bunch of writtens already, taking them now would put a smile on my face. Yet I find that it is what I enjoy least with flying, but I guess I need to learn to accept and enjoy it, because there is no end to them, hehe!
:p
