FlyChicaga said:
If you are flying a non-precision approach that requires maneuvering (such as the "arc" approach in NM... believe it is Las Vegas NM? Not sure), wait on the gear and flaps until you are sure of the landing. You just want to make sure you will have enough time to drop the gear, ensure they are down, and if they are not down to do the emergency extension procedure. That emergency procedure is fairly simple in the Seminole I fly now. If you are flying something where it will take 300 motions to pump the gear down, you may want to think about the gear earlier... or just be prepared for a gear-up landing.
FlyChicaga, there's no reason why you should have the gear and flaps out on a DME Arc. When utilized on either a precision or non-precision approach, the arc's function is to take you to the final approach course, after which you would then wait for the FAF if non-precision or a dot above the glideslope intercept to extend the gear and flaps.
About the only exception to this gear and flap rule would be if you were at a very high weight with a very high density altitude, and dropping these two would create such a high amount of parasite drag that you know you'd descend and auger it in on final approach. Then you'd want to wait as long as possible before you dropped gear and flaps. By high I mean something along the lines of at gross weight in an underpowered light twin at Leadville, CO on a horribly hot day...IE, a situation that is not typically encountered.
As for encountering gear problems, well, that would be a very rough day of flying when compounded with an engine failure in a twin, but I don't think any pilot would knowingly resign themselves to land gear up on the basis that they didn't want to deal with two problems at once...that would be incredibly stupid. This very scenario occurred on my friend's ATP checkride: Gear failure at the FAF on a non-precision approach while single engine. He had to demonstrate the full procedure while safely flying the airplane to ATP tolerances.
To use a real example, the hydraulic system on an Aztec is driven by a pump on the left engine. With a failure of the left engine, a pilot will have to deal with the engine-out AND pump 30-40 strokes on the emergency gear extension handle so they can get the gear down for landing.
Your boss, passengers, and insurance company would have your head if you told them "I landed gear up not because of a mechanical problem, but because I was just too occupied flying the airplane." Good luck finding a new job too. Just trim the airplane out, keep it above Vmc, drop the gear by whatever means necessary, and land. It's a lot of work, but it can be done.
