bertengineer
AM Aviation
- Dec 5, 2001
Asking the tower to verify is not a valid way to verify the gear is down and locked. The ONLY ways to be sure the gear is down and locked are the ones set forth by the manufacturer for that specific system. All transport category have redundant gear indication systems - primaries and backups. The backups can be anything from additional lights that are triggered by a different set of switches on the gear to ensure that it's down and locked(in case the main system fails to indicate such) to little windows in the top of wings that show a solid line( --- ) when the gear is down and locked, and a broken line( -_- ) when it is not. I've only seen those on a couple of old corporate jets, though.bertengineer said:What are the 4 ways to verify that the gear is down? I think I have a handle on a few.
1. 3 green lights
2. Unsafe gear indication would be lit if not down
3. Warning horn associated with flaps
4. Look at gear handle
5. Ask tower to verify?
any thoughts?
it's a given and I know you meant it when you stated Item#3....... but throttle position and the associated horn, or lack of.......if the gear has NOT extended..........bertengineer said:3. Warning horn associated with flaps
