Does anybody recall seeing a poster of humorous, but supposedly authentic early aviation regulations? I used to see it posted at different FBO's years ago. If you do remember the poster, do you remember any of the regs?
Regulations For The Operation of Aircraft
January, 1920
1. Don’t take the machine into the air unless you are satisfied it will fly.
2. Never leave the ground with the motor leaking.
3. Don’t turn sharply when taxiing. Instead of turning sharp, have someone lift the tail off the ground.
4. In taking off, look at the ground and the air.
5. Never get out of a machine with the motor running until the pilot relieving you can reach the engine controls.
6. Pilots should carry hankies in a handy position to wipe off goggles.
7. Riding on the steps, wings, or tail of a machine is prohibited.
8. In case the engine fails on takeoff, land straight ahead regardless of obstacles.
9. No machine must taxi faster than a man can walk.
10. Never run motor so that blast will blow on other machines.
11. Learn to gauge altitude, especially on landing.
12. If you see another machine near you, get out of the way.
13. No two cadets should ever ride together in the same machine.
14. Do not trust altitude instruments.
15. Before you begin a landing glide, see that no machines are under you.
16. Hedge-hopping will not be tolerated.
17. No spins on back or tail slides will be indulged in as they unnecessarily strain the machines.
18. If flying against the wind and you wish to fly with the wind, don’t make a sharp turn near the ground. You may crash.
19. Motors have been known to stop during a long glide. If pilot wishes to use motor for landing, he should open throttle.
20. Don’t attempt to force machine onto ground with more than flying speed. The result is bouncing and ricocheting.
21. Pilots will not wear spurs while flying.
22. Do not use aeronautical gasoline in cars or motorcycles.
23. You must not take off or land closer than 50 feet to the hangar.
24. Never take a machine into the air until you are familiar with its controls and instruments.
25. If an emergency occurs while flying, land as soon as possible.
