uwochris
Flightinfo's sexiest user
- Dec 21, 2001
Hey guys,
I was reading Kersher's book and came across something interesting.
In it, he mentions that for fuel injected engines, fuel psi will vary with throttle and mixture position, as it measures pressure at the fuel distribution manifold.
He also goes on to explain that for carb engines the fuel psi gauge usually measures the pressure somewhere enroute to the carburettor, and so, the fuel psi does NOT vary with power setting.
It seems that fuel psi should still vary with power on the carb engine because the engine driven fuel pump's RPM should depend on the engine's RPM setting (i.e. it is driven by the engine), and with lower throttle settings, the fuel psi should still be lower.
Also, he mentions that if you turn the electric fuel pump on in the injected engine, the engine flood; however, if it is carburetted, you could leave the pump on all day and there will be no flooding. Why is this?
Comments??
Thanks in advance.
Comments??
Thanks in advance.
