Fractionals and Logbook Pro
glasspilot
Hey, some of you ex Independence Air turned NJA guys who use Logbook Pro and APDL want to answer a question?
I too used APDL for all of the obvious reasons but am now going to work for a fractional. Does APDL still work for you or do you need the palm companion? If you need the companion then why do you and what benefit do you get from it. If you still use APDL are there any disadvantages?
Trying to figure out before hand if I should throw down the money to get the companion. Thanks in advance.
If you are going to work for NJA, then you can use the crew ops site to get your flight times anytime for any period. I can't see a reason to keep track of it yourself unless you just have a real need to keep track? It downloads in PDF or CSV(XLS).
