Guess I shouldn't have made that link live just yet.
Yes, it's true. The message board for Flight Options pilots is open over at asapflightdeck.com. It may be a couple of hours before we start approving guys for membership but you can go ahead and register.
The Flight Options board WILL assure your privacy. After you log in, your name will be checked with the current Options senority list to insure that you are in fact a current pilot. Once that is verified, all of your employee data is wiped from the board's database to ENSURE your privacy. Even if the board is hacked by an unfriendly weasel / bad manager....
The ONLY data remaining will be your chosen "handle" and password.
Well, how is the Flight Options Card Drive going? Are these things flooding in or is it just a trickle?
At the current attrition rate, 19 pilots departing so far in February with two more giving notice, I think that the seniority list will be most difficult to verify. I move up two or three numbers with each update.
The message board is open to any current non-management pilot flying for Flight Options. If you don't appear on the current seniority list as an active pilot, you're out of luck.
Unbelievable first 10 days response. Keep spreading the word. Print out those cards for crewmembers you run into who haven't yet heard of current push. With everybody's continued participation, the signature card drive should be rapped up by end of March!
