Rattler71
order out of chaos
- Dec 26, 2004
§ 91.151 Fuel requirements for flight in VFR conditions.
(a) No person may begin a flight in an airplane under VFR conditions unless (considering wind and forecast weather conditions) there is enough fuel to fly to the first point of intended landing and, assuming normal cruising speed -
(1) During the day, to fly after that for at least 30 minutes; or
(2) At night, to fly after that for at least 45 minutes.
§ 91.167 Fuel requirements for flight in IFR conditions.
(a) No person may operate a civil aircraft in IFR conditions unless it carries enough fuel (considering weather reports and forecasts and weather conditions) to--
(1) Complete the flight to the first airport of intended landing;
(2) Except as provided in paragraph (b) of this section, fly from that airport to the alternate airport; and
(3) (3) Fly after that for 45 minutes at normal cruising speed or, for helicopters, fly after that for 30 minutes at normal cruising speed.
Does this mean actually landing? Then planning a flight to the alternate, if required?
FlyingBuckI said:If this were the case, why would you need a fuel reserve? And why plan a flight to an alternate if you're already at your intended destination?
Unlike many 'gray' rules, this seems pretty cut and dry. I guess I'm not much for debating the obvious...?
avbug said:Projt,
A lot of regulations are written this way. The FAA in enforcement action may be able to establish that you didn't have enough fuel on departure, and the standard is a preponderance of evidence. If the FAA can do this, then yes, enforcement action may be successful.
If the FAA can show that you lasted twenty minutes into a five hour flight and ran out of fuel, the preponderance of evidence weighs heavily on the side of the FAA. If instead you landed with less than your reserve minimums or declared minimum fuel after encountering unforecast headwinds, then the FAA will have a much harder time making enforcement action stick.
So long as you reasonably take precautions and can show that you made the necessary calculations, you're set.
Personally, I'm a bit of a fuel weenie. That is, I dont' go flying around with minimum fuel, use minimum runway distances, etc. I don't ever want anybody to have the slightest ability to question weather I departed with adequate fuel or reserves.
Yes, the FAA does use different wording, but then IFR and VFR are different animals. You have more options under VFR. Under IFR, you had better have the gas, and the Administrator spelled it out as showing that you need to be able to complete the flight to the destination and then go for the alternate plus reserve, where applicable. However, this is all a flight planning issue. If you actually arrive with less fuel, this is not addressed by the regulation, which speaks to launching the flight, not ending it.
prpjt said:I personally have trouble translating these two things as saying the same thing.
By using VERY different wording, they seem to be trying to make a clear distinction. Let’s pick it apart.
