Falcon 2000 and 50 drivers
THE Flying Ace
I'm freaking out man
Those of you who know the 2000 and/or 50. How well will the 2000 and 50 operate out of a 3909 ft runway and 900 ft elevation? Please give the numbers for 30C, 20C, 10C and about how far you can go with those numbers.
Falcon 2000
@ 10c = 29949 lbs mtow. With our BOW, you will have 4494 lbs to split between trip / alternate required fuel and any payload, aircraft lands with 2000 lb fuel reserve.
@ 20c = 29554 lbs mtow. Again, with our BOW, you have 4099 lbs to split between trip / alternate required fuel and any payload, aircraft lands with 2000 lb fuel reserve.
@ 30c = 28696 lbs mtow. And again, you have 3241 lbs to split between trip / alternate required fuel and any payload, aircraft lands with 2000 lb fuel reserve.
Figure about 2500 lbs for the first hour, then 2000 for the next (your mileage may vary)
Falcon 50
Our empty weight= 22200
@30c=MTOW 32610 8000lb. useful with reserves
@20c=MTOW 34540 10000lb useful with reserves
@10c=MTOW 35130 10600lb useful with reserves
We plan 3000 first hour, 2400 second 2200 after. Same reserves (2000)as the above post.
