FAA Investigation
  • Thread starter Thread starter Drifter
  • Watchers Watchers 5
Drifter
Coming to a town near you
I have a "friend" who is being investigated by the FAA for doing some low level flying in a 172. What does it mean when they send your file to Kansas Aviation Council? Anybody had any legal problems like this before?
Thanks in advance.
Your friend should have received a letter of investigation (LOI) from the investigating inspector at the FSDO level. He will be given 10 days to respond, during which time he needs to keep quiet and contact an attorney. He needs to forgo an informal interview, if offered, unless he has proper counsel.
His case will be forwarded to the FAA legal counsel at the regional level for processing, and he will be assigned a penalty or enforcement action. He does not have the right to defend himself, as this is administrative law. He will be determined to be guilty based on the information available, including any statements made by him on his behalf (the most common source of evidence against pilots).
He has the right to appeal. To make best use of this right, he should contact an attorney who specializes in these matters, as early as possible in the proceedings.
Bear in mind that in these proceedings, a pilot is considered guilty until proven innocent. Also bear in mind that flying privileges are just that; not rights. The FAA may suspend, alter, or revoke them at any time, for cause.
What kind of low level flying was your friend doing?
He wasn't doing any low level flying. He was flying exactly at 500 feet above in ground IAW the FAR's. The reason they have the number of the aircraft is because it was the other pilot, or maybe the ground observer made a mistake. How can someone on the ground read an N number when it is moving at 2 to 3 miles a minute. In reality what kind of case does the FAA have-nothing-let them hang themselves. A good lawyer with a sense of humor will make them all look like fools.
I agree with turbos7 BUT......a 172 at 3 or even 2 miles a minute?! :eek: hahaha yeah, in a nose dive!:D
Unfortunately, I've read many cases where the FAA believes the non-pilot on the ground over the pilot resulting in a suspension.
My "friend" who is an instructor was practicing engine failures with a student and got a little too close to a soccer field where there were a bunch of moms who made formal complaints about "an airplane" getting too close to the field. Just as it happened... there was a dude from the FAA at the same soccer field which recognized the paint scheme on this airplane and found out who was flying it at the time (bad luck). By the time I found out about this the instructor in question had already admitted to being the pilot of the plane in question to the FAA. The student has already been questioned and cleared of the incident. But the instructor has had the case sent on to Kansas. The minute the instructor found out that there was an investigation, they got themselves a lawyer but its pretty expensive to talk to the lawyer and its hard to tell if the lawyer is doing anything about it. Is it time to worry now?
Drifter,
Just how close did this instructor get towards the crowd on the ground, and did he not notice them beforehand?
Unless they have the n number of the plane and have hard evidence like a radar track they have no case. It is all hear say, the FAA guy is a jerk and will show himself to be so.
There I was...
"The engine started running rough. I started to look for a suitable landing place and ran through the checklist, pull carb heat, and low (pun) and behold, it got better." End of story. End of Statement.
Your getting the picture. Just for the record there are some really nice FAA guys out there also, just like pilots.
Drifter,
Your friend is screwed (er, cooked). Most often the evidence used to support a violation during appeal proceedings is based on the admission of the pilot.
He needs to steer clear of built-up or populated areas, period. Perhaps this will serve as a wake-up call for common sense.
Flychicaga, yes, I'm familiar with the process. Every pilot should be intimately familiar with the regulations and the enforcement process. Failure to do so is a serious shortcoming on the part of that individual, and it can cost him or her their career. In my own case, I'm familiar with the proceedures based on prior understanding, and several bouts of personal experience.
The instructor never got closer than 700 - 1000 AGL. Another problem is that since the student was not performing to standards, they did three engine failures into the same field. Yes they did notice the people on the ground but the instructor wanted to demonstrate the right procedure into the same place in order to get some consistency into the student. Everything I have written here is what he has said to the FAA. There really was no reg that was broken but this seems like it is getting pretty serious even though he did nothing wrong (at least as far as I can tell).
Drifter,
I completed a lengthy legal reply with several FAA Letters of Interpretation by the Assistant Chief Counsel, relating to your (friend's) situation. However, computer problems lost it, and I don't have 45 minutes to recreate it. I have included one LOI below that relates in part to your question.
Bear in mind that the FAA has held on several occasions that a few occupied houses or a very small gathering of people consititute a built up area. 91.119(b) applies.
The letters of interpretation are primarily from the late 70's, and refer to 91.79, which is now 91.119. They still apply. One of the LOI's that was lost to my deeply disturbed computer referred to an attempt to excuse violating altitude restrictions based on the need for a law enforcement officer to observe a suspect. The Assistant Chief Counsel noted that unless a bonafide emergency existed, then the officer's actions (specifically those of the pilot flying the officer) were not justified, and were not legal.
If the requirement for a law enforcement officer to perform a lawful function does not justify an exception to the altitude limitations, then you may suppose (rightfully) that a flight instructor will have a hard time using a desire for "consistancy" as an excuse. It likely won't fly.
In addition to 91.119(b), the FAA may elect to look to 91.13 for enforcement action, based on the admission of the pilot in your scenario that he was aware of the presence of people on the ground (but elected to proceed repeatedly, anyway).
Simply moving to a different location might have saved a lot of heartache.
The following Letter of Interpretation includes some information relevant to your question.
JAN. 5, 1978
F. DENNIS HALSEY, ESQ.
Dear Mr. Halsey:
This is in reply your letter of October 25, 1977, in which you state that your firm is involved in a wire strike case and you request information on the legislative history of Federal Aviation Regulation (FAR) Section 91.79 with respect to the 1000 and 500-foot minimum altitudes, and on the class to be protected by these altitude restrictions. You also request information on the application of case law to FAR Part 91. In a telephone conversation on November 15, 1977, you requested a judicial interpretation of the term "congested area", and any case law that tended to place responsibility on the property owner in wire strike cases.
Our files are incomplete prior to the creation of the FAA by the Federal Aviation Act of 1956. Also, before the Administrative Procedure Act in 1946, the policy or basis of Federal rule making usually was not disclosed or subjected to public comment. Therefore, we generally rely on the Code of Federal Regulations (CFR) and citations therein to the FEDERAL REGISTER for our research. Utilizing these sources, we found that the minimum safety altitudes of 1000 and 500 feet were prescribed in the earliest edition of the CFR (rules in effect as of June 1, 1938).
Regarding the class of persons to be protected, paragraphs (a) and (d) of FAR Section 91.79 specifically refer to operations without hazard to persons or property on the surface. An earlier amendment to Section 60.105 of the Civil Air Regulations (CARs) which preceded the FARs, published on May 3, 1945 (10 FR 5068) was more explicit by stating that flight below 500 feet is allowed only where such lower altitudes will not involve hazard to persons or property on the surface.
With respect to your requested definition of the term "congested area" as used in Section 91.79 of the Federal Aviation Regulations, the term has been applied on a case-by-case basis since it first appeared in the Air Commerce Regulations of 1926. That term has never been defined in any regulation. However, guidelines may be found in decisions issued by the Civil Aeronautics Board (CAB) and more recently by the National Transportation Safety Board (NTSB) in attempting to give the term fair and equitable effect. Decisions of the CAB through 1959 are reported in Civil Aeronautics Board Reports, published by the Government Printing Office, and may possibly be found is larger law libraries. NTSB decisions, indexed in digest form, are available through a subscription service published by the Hawkins Publishing Co. and also may be found is larger law libraries.
These guidelines may be summarized as follows:
1. The term is administered to protect persons and property is small, sparsely settled communities, as well as persons and property in large metropolitan areas from the hazards of low flying aircraft. Thus, size of the area is not controlling, and violations of the rule have been sustained for operation of aircraft (i)over a small area consisting of approximately 10 houses and a school, (ii) over the campus of a university, (iii) over a beach area along a highway, and (iv) over a boy's camp where there were numerous people on the docks and children at play on shore.
2. The term has been administered to prohibit overflights that "cut the corners" of large, heavily populated, residential areas.
As is made clear in the rule, the congested area must be an area of a city, town, or settlement. However, so precise density of population, ground traffic, or congestion, or precise description of the proximity of buildings or number of residences, has yet been devised that will achieve both the intended protection of persons and property on the ground and fair application of the rule to operators of aircraft. If you wish to research, in depth, the current NTSB decisions concerning "congested area," we suggest you contact the General Counsel's Office of the NTSB, Suite 800 East, 800 Independence Avenue, SW., Washington, D.C. 20591. I have enclosed a recent NTSB opinion and Order (SE-3537, November 28, 1977) that may be a good starting point for research in this area.
We regret the delay in responding to your request. If you have further questions, please let us know.
Sincerely,
NEIL R. EISNER
Enclosure
Avbug, thanks a bunch for taking the time to post that. Can I ask you where you get this type of info? Are you using a law library or something? Can I access online?
Thanks again bro,
Drifter
Drifter,
I use various sources, but generally refer to the Summit Publications CD, which has every FAA publication on one CD/Rom. You can get it from ASA for about eighty bucks. It's handy for fast references in large volumes of material.
Aviation attorney
Drifter, your "friend" should find himself legal counsel as soon as possible and stop dealing with this himself. The feds have tricks up their sleeves that only aviation attorneys can deal with.
Have your "friend" call the AOPA ASAP for referrals.
I always recommend this book, Practical Aviation Law, by J. Scott Hamilton, ISBN: 0813818176, as mandatory reading for pilots. It's a great book, available at amazon.com, bn.com, and maybe even at your local FBO.
Best of luck to your "friend." He'll need it.
