Is a flight attendant required on an aircraft with 19 or less passengers regardless of the capacity of the aircraft? I believe the answer is no. However someone is required to give the passengers a safety demo. Sorry if in not the most applicable forum. Not many on the FA forum.
What sounds more accurate? You just had 2 different individuals give you the correct answer, yet you still act as if your answer is correct which it is not.
An MD80 has a SEATING CAPACITY which would require 3 FAs. If there are no FAs on board, then there are NO PASSENGERS. If there are 2 FAs on board, then there are also NO PASSENGERS. Since an MD80 seats 100 or more but less than 150 passengers in capacity, it requires 3 FAs, regardless of the actual number of passengers on board.
The MD80 crew that you heard in ATL could not have occurred. Passengers cannot occupy a ferry flight, nor can they occupy a reposition flight since neither are scheduled 121 operations. If an airline chooses to operate a reposition as a 121 flight, it can be placed into operation as an extra section, but then it's no longer a repo. It's now a scheduled operation and again, requires the specific number of FAs per the regs.[/QUOTe and a E]
Hate to tell you your wrong but it is possible at least at DAL.The key being the pax are all employees, Ive done it both on the DC10 and 757...
I've also seen this done 121, no FA. The captain was not really happy about it but the DO said it was 100% legal. All PAX were badged uniformed airline crew, not just non-rev.
A. If the aircraft is wholly airworthy, a reposition flight will be planned/released the same way as any other flight. Carriage of non-revenue passengers when a flight attendant is not on board may be authorized, subject to the limitations of FAR 91.533, and subject to approval of the DO, SOCM, or FODM, or other flight department management personnel, as appropriate. Flight crewmembers only should be accommodated on these flights, subject to Captain’s discretion. Pass eligible dependants should not to be accommodated on these flights. When any non-revenue passengers are carried on a reposition flight, their names and ID numbers should be added to the flight release as a release remark, or be listed as deadheaders in CrewTrac. The release must be remarked as “FAR 91 REPO FLT – RELEASE INFO ONLY”, or something to that effect.
I'm sure they were "overstaffed" in the first place--and even without the "full complement" they still likely had a min-crew.I've ridden on Delta and North West flights without a full complement of flight attendants.
I was in uniform both times on my way to work, and both times they were missing one FA, the NWA flight a FA delayed the flight until she ran out of time, but not 16 hours a contractual time that it was her choice to continue. The Delta flight was a similar situation.
Wouldn't it all depend on how the flight was released a ferry or a repo flight if the release was signed it would be a 121 flight.
Ultra yes I am a 121 Captain current qualified, been so for the last 12 years or so.
Long time gone dude...
No comment, just a bit dissapointed to see a collegue so quick to pass judgement assuming you are a collegue.
I fly a 737-700 with 19 seats in it and we are not required to have a FA. Never had one, actually. We have Customer Service Representatives.
I'm not saying you haven't...but I'll bet it's not Pt 121. It's a Pt 91 or 91K. Right?
Pace, in 2002 was offered a contract on an ambulance rated 737 with 12 seats and ultimately we turned it down b/c of the conformity checks and contract-term were too short...but b/c of MTOW it did require an FA; to fly it as a Pt 121 gig.
It can all be true...just depends on the CFR etc under which the operator wants to fly.
